Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Engine Management: Access Port -+ Ft/lb, HP, Fuel Economy Etc.!
Old Aug 11, 2008 | 01:36 PM
Iperformancellc's Avatar
Smile Major Xmas Sale :G35\G37 Access Port -+ Ft/lb, HP, Fuel Economy Etc.!
COBB TUNING G35 Access PORT - AP-NIS-002
COBB TUNING G37 Access PORT - AP-NIS-004
FREE OVERNIGHT SHIPPING IS ALWAYS INCLUDED FOR MEMBERS
ALSO NOW AVAIABLE!
G37 AccessPORT
The AccessPORT is the first hand-held device available for the Infiniti G37 that performs an ECU reflash through the vehicle's OBDII port. Just plug it in, load the map and go! Faster!
The AccessPORT provides owners of 2008 Infiniti G37 vehicles the ability to unlock power hidden within the factory ECU. Performance gains across the entire powerband can be quickly realized in the short time it takes to flash the vehicle's ECU with the AccessPORT. No tools are required. No mailing the factory ECU across the country. No vehicle downtime. No waiting. And waiting. And waiting! Just plug the AccessPORT in, flash the ECU and enjoy the thrill of increased torque and horsepower!
Part No. Application Price
AP-NIS-004 Infiniti G37 2008 $695.00
$695 SHIPPED + CASH BACK REWARDS (ASK ABOUT THIS)
IN STOCK ALL ORDERS AVAILABLE FOR OVERNIGHT SHIPPING WHEN IN STOCK
Fits: Infiniti G35 2003-06 ; **Excluding 2003-early 2004 G35 Sedans
*(Check www.cobbtuning.com often for map and model availability Updates)
Please Note: This part will only work with North American Infiniti G35. Also be aware that this device is currently not compatible with G35 Sedans with build dates from 2003 through May 2004. The ECU Part Numbers for these vehicles are as follows: - AM600 - AM601 - AM601 - AM602 - AM603 - AM604
Details:
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer. The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel!
But the AccessPORT is so much MORE than just a RE FLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for costly and cluttering after market gauges! With the added ability to adjust timing and idle, the AccessPORT is truly more than just a programmer, it is the ultimate all-in-one solution for the G35 enthusiast.
MORE INFO:
These units were designed as a answer to all your tuning needs. These were first developed for the Subaru applications and are now out selling turbo xs 3 to 1. They are plug in play inside your vehicle, Easy to use, easy to tune on your own, they have live displays like air\fuel, boost, egt temp, etc. They are also the size of an I pod can be mounted any were or hang free, and come with a color screen for easy to see fuel maps. No laptop required, the list goes on and on.
INSTALLATION:
Just about anyone with even the most basic of automotive knowledge can quickly and easily install an AccessPORT. No soldering, wire cutting/splicing or tools required.
AccessPORT Settings:
Customize the AccessPORT by changing settings, such as selecting the language for displaying text.
About AccessPORT:
Displays information about the AccessPORT firmware, serial number, and vendor. Easily check to make your AccessPORT stays up to date with the most current firmware.
Mode Switching:
Change mode of engine management for staged performance, fuel economy, theft deterrent, race mode or custom performance.
Show Current Map:
The AccessPORT can display the last map it applied in real time and the last map that it reflashed. To see the current map, select “Show Map” from the AccessPORT main menu.
Fuel economy gauge:
Monitor average and instantaneous fuel economy estimates to improve your driving techniques for optimal fuel efficiency. Customers have seen over a 5%-10% improvement in fuel consumption when used in conjunction with the Fuel Economy Map.
Display engine parameters:
Check vehicle performance by monitoring engine parameters. The AccessPORT can read sensor data from the factory ECU and display it on screen. This feature allows the AccessPORT to function as an auxiliary gauge to display RPM, Boost, Coolant Temp., Battery Voltage, Intake Air Temp., Ignition Timing, Mass Air Flow and many more.
Rev Warning/Shift Light:
The screen will flash to indicate that a pre-set shift RPM has been exceeded while viewing engine parameters. The pre-set shift point is user settable through the SETTINGS menu.
Performance:
The AccessPORT measures and displays 0-60 mph acceleration,
60 ft. time, 1/8th and 1/4 mile E.T. and Trap Speeds. Use this feature to quantify performance modifications and driving techniques.
ECU Tool & Settings:
Control basic engine functions and conveniently reset the ECU from the comfort of the drivers seat instead of manually disconnecting the battler and losing all your radio presets and having to reset you clock.
Read engine diagnostic codes:
Avoid an expensive trip to the dealership by reading the codes describing an illuminated check engine light. The provided code description may help to determine the cause of a problem.
AccessPORT (Stage 1 Kit) Includes:
- AccessPORT
- Quick Start User Guide
- USB Cable
- OBDII Connector
- Software CD
Nissan G35 AccessPORT features are as follows:
» Improve horsepower, torque, and fuel economy at the touch of a button
» Adjust timing +/- 2 degree's
» Adjust idle +250rpm
» Display vehicle data such as RPM, temperatures and more while you drive
» Easy installation, no mechanical or computer skills necessary
» Connects to your vehicle via the OBD-II port conveniently
» Exclusive ability to switch between different 'modes' on the fly
» Pre-calibrated to maximize performance of stock or modified vehicles
» Easy-to-read color display
» Update over the Internet to stay up-to-date with the latest features
» Read engine trouble codes (DTC) yourself, eliminating trips to the dealership
» Not a "piggyback" - once vehicle's computer has been programmed by the AccessPORT, it can be removed and the settings will stay on your computer.
» Not just an "ECU reflash" - AccessPORT features enhancements such as on-the-fly mode switching, data monitors, reading DTCs, performance monitors and more
» Can be custom tailored to your vehicle by our extensive network of professional tuners
Old Aug 11, 2008 | 01:38 PM
FAQ 4 The Homies
FAQ- QUESTIONS ASKED
Question 1:
Well i just read on the cobb tunning website that both stage 1 and stage 2 maps dont allow you to have anything more than a cat back exhaust. what are those with intake, test pipes, plenum spacers, etc. supposed to do? according to the website any of those with intake mods will be running extremely lean a/f ratios. theres no way around this?
Answer:
You need to get a pro tune to run addition mods when using an off the shelf Cobb map. A pro tune is the ONLY way around it!
Question 2:
What is the average hp gain? Customer Specsintake, plenum spacer, test pipes, cat back). Will this make my car run leaner than it all ready is?
Answer:
Follow the link below- it will show him the HP gains for all the different MAP they have.
http://www.accessecu.com/accessport/nissan/350Z.html
If you click on the MAP NOTES link, it will show you even more detailed information about each map (hp numbers, mods that are required when running set map, fuel requirements, ect..)
Question 3: Is it available for a 2007 G35 6mt Coupe?
Answer:
It has not been released on the 2007 model yet, Cobb is currently working on it but has not ETA on the release at this time.
Phone #
407.412.9551
Fax #
866.295.3077
- Fax Orders with your Name, Shipping Address, Part Name(s) & Model #(s), Phone #, Email address and credit card/billing information and/or description of how you would like to pay.
Business Hours (Phone | Fax Inquiries):
Mon-Fri 9:00 AM to 5:00 PM EST
Instant Messaging (Online 24-7) :
YAHOO - Integratedperformancellc
MSN - IntegratedPerformancellc@gmail.com
SKYPE - Integrated.Performance.llc
AOL
Jason Buchanan, Retail | Wholesale Manager: IpllcJason
- Branden Kleiser, Audio | Investor Relations Manager: IpllcBranden
Email:
Any Questions - General Questions
Order Info & Tracking - Tracking Requests & Order Information
Wholesale & Parts Manager - Jason Buchanan - President
Audio & Investor Inquiries - Branden Kleiser - Vice President
Office Locations:
-Mount Dora, FL*
Distributor | Warehouse Locations:
-Mount Dora FL* , Miami FL* , Allentown PA*
*No Customer Pickup's at any location at this time
Old Aug 15, 2008 | 11:43 AM
Bring It Up
Old Aug 15, 2008 | 11:48 AM
SunnY-D's Avatar
are you guys working on something like thing for the 2nd gen sadans?
Old Aug 15, 2008 | 12:10 PM
actually its Cobb Tuning, who produces these units, and yes they are right now. If your in the utah area and can spare your vehicle they are looking for loaner cars for testing. What year is your car 2008?
Old Aug 15, 2008 | 12:15 PM
Smile COBB AP MAPS- Availabilty
Here is the current application guide, and Map downloads :
http://www.accessecu.com/accessport/infiniti/G35.html
Old Aug 15, 2008 | 11:56 PM
SunnY-D's Avatar
my car is a 2008 g35X... but unfortunately i live in NYC. but im sure there is someone on this site from utah.
Old Aug 16, 2008 | 10:09 AM
There are a few G37 users and gen 3 g35 Users who had custom tunes, if you have the same setup you may be able to get a map from them to start as a base, so you dont run lean
Old Aug 27, 2008 | 03:32 PM
Bring it up for the AP
Old Aug 29, 2008 | 05:41 PM
Gtr Ap Now Available
Old Sep 5, 2008 | 12:06 PM
These are HOT who wants one!
Old Sep 17, 2008 | 02:24 PM
Bump this for the new BETA site with 90,000 items listed for Forum Members only!
Link: www.JBKperformance.rpmware.com
Old Oct 1, 2008 | 01:58 PM
BRING IT UP FOR www.JBKPERFORMANCE.com
Old Oct 6, 2008 | 11:28 PM
Awesome Part Any Takers????
Old Oct 10, 2008 | 01:17 PM
Bring It Up !!!
