Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Nrg Engine Products!!!! Free Shipping!!!
Old Aug 15, 2008 | 07:22 PM
Jo@shopjspec's Avatar
NRG ENGINE PRODUCTS
OIL CATCH TANK (universal)
PM FOR PRICE!
Installed connecting the PCV Valve or pressure release hose to the intake pipe, this unit captures and stores excess oil coming from valve cover. This results in clean air recirculating back into the intake unlike the factory system which puts the release tube directly back into the engine. Results a decrease in valve cover pressure prolonging engine life and increasing performance.Also a must in any competition car due to regulations concerning oil on the track.
POWER STEERING RACE TANK (universal)
PM FOR PRICE!
Race application power steering reservoir.
FUEL REGULATOR (universal)
PM FOR PRICE!
Installed onto the fuel rail or in-line with fuel lines, this units allows fine turning of fuel curve mechanically by increasing or decreasing fuel pressure to the fuel lines. Boost dictated to steady fuel pressure even under boost conditions resulting from forced induction.
FUEL REGULATOR GAUGE
PM ME FOR PRICING!
RADIATOR CAP (universal)
PM FOR PRICING!
This unit was designed to reduce underhood temperatures by increasing and maintaining the internal water pressure of your vehicles cooling system through the utilization of a stiffer valve spring in the cap housing. This allows for much better flow and consistent running temperatures.
VOLTAGE STABALIZER (universal)
PM FOR PRICING!
Connected to battery terminals, this unit stabilizes power output to all electrical components drawing power from battery. Using an independent power source, this unit boosts batterypower when under high loads, thus regulating fluctuations coming from the battery that can result in loss of power or responsiveness from ignition system components. Can also improve interior lighting as well as stereo equipment performance.
GROUND WIRES
PM ME FOR PRICING!
Installed on battery? negative terminal or onto chassis, this unit centralizes the grounding point of the electrical mechanisms of the vehicle. This causes less fluctuation for the electrical system and can improve overall performance and responsiveness of the engine end electrical components resulting from proper grounding. A must-have for any vehicle with engine swaps since grounding tends to be an issue with these types of performance modifications.
~CA sales are subject to sales tax~
Old Aug 19, 2008 | 05:53 PM
back up top!!!
Old Aug 28, 2008 | 02:26 PM
TO ORDER CHECK OUT OUT OUR SITE @ www.ShopJspec.com!!!!
Old Aug 31, 2008 | 06:12 PM
hyperlite21's Avatar
any reviews on the catch can?
Old Sep 2, 2008 | 03:19 PM
pm sent!!!!
Old Sep 16, 2008 | 03:52 AM
Check out www.ShopJspec.com 4 prices on all the products you see on the forums!
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
Detailed Image
Jul 29, 2015 08:42 AM
Detailed Image
Jul 24, 2015 12:31 PM
ClwMike
Jul 23, 2015 12:55 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
