Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Megan Polished Radiator Breather Tanks!!
Old Sep 4, 2009 | 04:35 AM
mrwong@statik's Avatar
Model Number : MR-BT
Having a vehicle that is intended for competition is not an easy task, you must ensure that every aspect of your vehicle works properly and with one another to have a balanced and competetive vehicle. The powerplant must work with your drivetrain and your drivetrain with your suspension, and your suspension with your chassis. One of the biggest parts of the powerplant system that is overlooked is your cooling system.
Many tuners will tell you how crucial your cooling system is to not only the overall performance of your engine but the durability and reliability. Most modern engines are cooled via an Liquid-Air cooling system. Most common upgrades are upgraded radiators that are more efficient, electric fans that have higher CFM's, caps that have higher pressure releases and hoses that have higher burst-pressures as well as less expansion. With all these upgrades available, most people still forget that a cooling system must be properly maintained and monitored.
The reason your cooling system is pressurized is to increase the boiling point of your coolant; the physics of liquid state that it cannot be compressed, because of this any air in the system WILL compress and allow the coolant to expand and evaporate. If an air bubble gets trapped in your system then coolant will not flow propery which can lead to an inefficient cooling system.
Megan Racing has developed a Breather Tank that routes through several key places on your cooling system; Lower Radiator Hose, Cylinder Head, Expansion Tank and Radiator Neck. Once these ports are all connected and the Breather Tank is placed at the highest place in the cooling system; it will allow a more efficient way to fill and maintain the coolant system while evacuating any air from the system.
The system includes:
1 - 1/8NPT 3/8" Barb Fitting
1 - M5x1.0 5/16" Barb Fitting
1 - 4-Port Aluminum Breather Tank
6" of 3/8 Clear Hose
Installation Hardware
$85 Shipped!! Anywhere in the 48 States!!
Old Sep 8, 2009 | 04:54 AM
pms replied..
Old Sep 15, 2009 | 04:55 AM
pms replied..
Old Sep 22, 2009 | 05:36 AM
pms replied..
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
