Engine-Vendor Includes cams, clutches, flywheels and all other power related components.
Mishimoto Cooling products!! Free 2nd Day Air Shipping.
Old Oct 22, 2011 | 01:48 PM
b2autodesigns's Avatar
Hello Guys,
We have the following parts in stock from Mishimoto!!! Get what you want fast. We want to earn your business!!! Check us out.
Mishimoto has released the new bolt on oil cooler kit for the G35 coupe.
Mishimoto has announced the release of the all-new Nissan 350Z / Infiniti G35 Coupe Oil Cooler Kit. Specially designed for the Nissan 350Z and Infiniti G35, the Mishimoto oil cooler is a direct fit and works with both manual and automatic applications. Proven to reduce engine oil temperatures 25 degrees, this oil cooler kit is a must have for your 350Z or G35. The Mishimoto 350Z / G35 oil cooler kit is available with an optional thermostatic sandwich plate for safe daily-driver warm up and additional operating temperature control.
Increase In Oil Capacity: 0.65 Quarts (0.613 L)
Temperature Difference: 25 degrees
Pressure Drop: 2-3 psi
Purchase Includes:
(1) - Application Specific Mounting Bracket
(1) - 19 Row Oil Cooler
(1) - 4ft Stainless Steel Braided Hose w/ -10AN Fittings
(1) - 5ft Stainless Steel Braided Hose w/ -10AN Fittings
(1) - Oil Sandwich Plate M20 (Thermostatic Plate as Option in Drop Down)
(1) - Stainless Steel Sandwich Plate Adapter, M20
(2) - Banjo Fitting w/ Bolt M20 x -10AN, Black
(1) - Mounting Hardware Set
Also Fits : 2003-2009 Nissan 350Z & 2003-2007 Infiniti G35 (Coupe only)
Engine Codes: VQ35DE & VQ35HR
Chassis Codes: Z33 & V35
Youtube video install:
Infiniti G35 Performance Aluminum Radiator, Manual and Auto transmissin 2003-2006:
Auto transmission comes with built in trans cooler.
The Mishimoto performance aluminum radiator for the Infiniti G35 is the ideal upgrade to the stock G35 radiator. Designed and specifically engineered to maximize cooling efficiency by up to 30%, boost engine functions and protect your car from overheating. Whether you use your Infiniti for daily driving or take it to the track, many people overlook the importance of installing an upgraded radiator in their engine. A stock radiator can not handle the heat that comes along with having a great deal of horsepower. The Mishimoto Infiniti G35 radiator features a lightweight dual core, 100% brazed aluminum, and polished end tanks. Every Mishimoto Performance Radiator is a direct OEM fit, making installation effortless, no cutting or modification is required. All Mishimoto radiators come with a high pressure 1.3 bar Mishimoto radiator cap and an excellent warranty
Mishimoto hose kits: 4pc kit. Offered in red, black and blue finish.
KOYO Radiator
Please message me for best pricing:
Mishimoto Oil Cooler:
Rows: 10
Core: 11.81" x 5.31"
Thickness: 1.97"
Braided Hoses: 4ft .75 inch 4ft 9 inch
Braided Hose Fittings: 10AN
Sandwich Plate Screws: -8AN
Black or silver finish:
Mishimoto dual pass oil coolers: 19 and 25 row.
Mishimoto Universal black or silver 10, 19 and 25 row oil coolers.
Mishimoto Aluminum Oil Catch Can - Small
Mishimoto Aluminum Oil Catch Can - Large
Mishimoto Aluminum Coolant Reservoir Tank: Black red and polished finish.
Mishimoto Aluminum Power Steering Reservoir Tank: Black, red and polished finish.
Mishimoto Eat Sleep Race Special Edition Gold M-Line Intercooler:
Pm me or call 813-787-4075 for best pricing or with any questions you might have.
Thanks
Charles
Old Oct 24, 2011 | 09:04 PM
Mishimoto NEW Baffled Oil Catch Can:
Overall Height
6.00” (without fittings)
Overall Diameter
3.06” (without fittings)
Inlet
M20 x 1.5 (for accepting -10AN)
Outlet
M20 x 1.5
Drain Plug Thread Size
M20 x 1.5
Capacity
9 fl oz.
Assembled Weight
1.6lbs (0.73kgs)
Purchase Includes
1 – Black, Anodized 6061 Aluminum Catch Can
2 – Aluminum Mounting Brackets
1 – Bronze Filter
1 – Internal Baffle
3 – Dowty Oil Seals
2 – Push-on Fittings
1 – Drain Plug
1 – 6’ Black Rubber Oil Line
4 – Worm-gear Clamps
1 – Black Rubber Band
Mounting Hardware & Brackets
Limited Lifetime Warranty
Message me for best pricing.
Thanks
Charles
Old Oct 29, 2011 | 06:19 PM
all pm sent
Thanks
Charles
Old Nov 4, 2011 | 11:36 AM
all pm sent
Thanks
Charles
Old Nov 10, 2011 | 09:33 AM
Join us on Facebook: Always got deals going on!!!
https://www.facebook.com/#!/pages/B2...s/165793298063
Thanks
Charles
Old Nov 15, 2011 | 04:08 PM
all pm sent
Thanks
Charles
Old Nov 15, 2011 | 04:30 PM
lsmooth81's Avatar
Charles, do you know if mishimoto is coming out with a radiator for the 5AT that doesn't require modification? Thanks
Old Nov 15, 2011 | 04:35 PM
No they don't. Have to mod to fit the AT.
Old Nov 21, 2011 | 08:31 AM
all pm sent
Thanks
Charles
Old Nov 26, 2011 | 12:26 PM
All pm sent
Thanks
Charles
Old Nov 30, 2011 | 07:49 PM
dorkstar's Avatar
Mishimoto Aluminum Coolant Reservoir Tank and 4 pcs hose kit red shipped 90712
Old Dec 6, 2011 | 01:54 PM
all pm sent and thanks for the orders guys.
Thanks
Charles
Old Dec 12, 2011 | 12:18 PM
bump
Thanks
Charles
Old Dec 16, 2011 | 11:12 AM
JD_AND_DA_G_RIDE's Avatar
Quote please...feel free to PM
6mt 03'
Mish Radiator with and without hoses to 75240
Oh and I know it comes with a stock mish cap...but how much for the other caps...CF and temp gauge one?
Thanks,
JD
Old Dec 19, 2011 | 03:31 PM
all pm sent
Thanks
Charles
