Motordyne Engineering Plenum Spacers and MREV!
#61
on
#66
Modded Member
I've got a shopping cart full of items on your site (GT Spec Lower tie bars, lateral bar, and 5/16" copper ISO kit), but wanted to see if you have the new "MREV+" upgrade that Tony developed for the automatic G's on the site as well. Can you please confirm, or link me to the product so I can complete my checkout?
Thanks!
Thanks!
#69
on
what I had discussed with vodkarocket was about what kit he wanted to get for his sedan. What has been proven to work on the sedans is the MREV+ kit.
http://www.partshippers.com/index.ph...roducts_id=910
But in some cases, people already have spacer kits installed - 5/16" iso thermal kit, or an aftermarket upper plenum, etc. In those cases, they would just be interested in buying the machined lower intake plenum.
http://www.partshippers.com/index.ph...roducts_id=905
That's about it.
That's about it.
#70
#71
dont knkow if anyone has asked you this? but if you plan on adding a turbo in the near future is this intake going to make be somthing that you have to take back off? if now Im game cause I think the supercharged idea is off cause stillen has failed to address a decent hood for the car... Im going single turbo so far...
#72
#74
The general rule seems to be this.
If your FI increases engine power 50%, it will also increase plenum mod gains by 50% as well.
And the spacers are being used in built FI G35's with over 22 psi of boost and 700+ HP!
Raven7
08-14-2015 04:40 PM
