Exhaust-Vendor Includes Headers, Test Pipes, Y-Pipes, High Flow cats and Cat-back Systems
Berk Technology HFCs and Test Pipes
Old Oct 6, 2009 | 05:01 PM
Marinelli Motorsports's Avatar
Berk Products
Nissan 350Z 03-06, Infiniti G35, Metallic Substrate HFC's:
MSRP:499.99
"Metallic substrate HFC's. Spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Perfect for forced induction use. Made in the USA."
Nissan 350Z 03-06, Infiniti G35 Coupe 03-06, 02-05 Sedan Test pipes:
MSRP:179.99
"Dual 60mm Test Pipes w/ Built in O2 CEL fix. Additional O2 Bung Included on both pipes for left bank & right bank wide band O2 fuel tuning. Full 304SS. Built in CEL fix is ~95% effective in most cases. Your results may vary."
Nissan 370Z, 350Z 07-up, 370Z, & Infiniti G37/G35, VQ35HR Metallic Substrate HFC:
MSRP:549.99
"Metallic substrate spun catalytic converters, OBDII & 49 state compliant. Full stainless steel construction. Metallic substrate offers higher flow and lighter weight. Uses advanced spiral wound ultra thin foil. Includes our custom made soft crush graphite collector gaskets for a leak free seal. These are made specifically for the new HR motor by BERK. Made with pride in the USA. As of January 1st, 2009, performance high flow cats are intended for off-road use only in the state of California."
Nissan 07+ 350Z/G37/G35, 09+ 370Z Test Pipes:
MSRP:349.99
"Our highly anticipated 2007-up test pipes are now available! Features fully gusseted and plated support brackets, the strongest in the industry. Includes the same leak free soft crush graphite collector gaskets found in our 07- up HFC's and secondary O2 sensor bungs for wideband tuning or AF monitoring. Plugs included when not in use. Mechanical CEL fix included, but on the 07-up HR motors it is less effective than the 03-06 motors. Full 304 stainless steel construction, made the right way in the USA."
Please PM me with location for best price shipped.
Old Oct 6, 2009 | 10:58 PM
All PMs replied!
Old Oct 7, 2009 | 07:09 PM
All PM's replied!!!
Old Oct 8, 2009 | 02:42 PM
Bump
Old Oct 10, 2009 | 06:49 AM
All PMs replied
BUMP!
Old Oct 10, 2009 | 10:42 PM
4DGS's Avatar
When does this group buy end man?
Old Oct 10, 2009 | 11:03 PM
PM replied
Old Oct 12, 2009 | 08:56 AM
Bump
Old Oct 13, 2009 | 09:29 AM
All PMs replied!
Old Oct 14, 2009 | 10:37 AM
All PMs replied.
Biz-ump!
Old Oct 15, 2009 | 10:06 AM
All PMs replied
Old Oct 16, 2009 | 02:55 AM
by15vc's Avatar
Price for HFC 06 coupe shipped to 90034, thanks
Old Oct 16, 2009 | 04:02 AM
You've got mail!
Old Oct 16, 2009 | 12:44 PM
davesxx01's Avatar
Got my HFC's today. Look good but there are no gaskets included? Instructions?
Which sensor goes in which hole??
Old Oct 16, 2009 | 12:57 PM
I do not believe they come with gaskets or instructions ( I know mine didn't when I bought them earlier this year). Now they do sell the gaskets seperatly. As for the sensor I assume it goes into the taller hole just to make sure no check engine light comes on, but I looked under my car and mine are actually on the front ones (never had a CEL issue) That being said I don't think it matters which ones they are placed in.
