Exhaust-Vendor Includes Headers, Test Pipes, Y-Pipes, High Flow cats and Cat-back Systems
Amazing Deal on Borla Exhausts for the G35! Check it out!
Old Dec 29, 2009 | 02:35 PM
Mike@CZP's Avatar
Hey Guys, we have this great deal on Borla Exhausts for the G35. They are $1,140.99 shipped anywhere in the US for the Coupe version and $870.00 shipped for the Sedan version. Simply select "Add to Cart" to be directly linked to our website.
**When ordering the G35 Coupe Borla Exhaust, make sure to put "G35Driver quote for $1,140.99" in the comments section when ordering to get the discounted price**
Coupe Description:
The Borla True Dual Exhaust SS System is one of the best Exhaust systems on the market for the G35 coupe. The System uses a true Dual Design, which eliminates the Y-pipe. This results in better flow and more HP. The HP gains have resulted as 16-20 HP. The System weighs about 12lbs less than the Stock System on the car.
Borla G35 03-07 Coupe True Dual Exhaust SS System, $1,140.99 Shipped
Fast Shipping!
Sedan Description:
Borla Performance Industries is proud to announce the release of Cat-Back™ system. This system has been designed for the 2003+ Infiniti G35 4 door sedan equipped with a 3.5L V6 engine and automatic or manual transmissions. The exhaust installs to the factory flanges located just after the catalytic converters and is made from full aircraft quality T304 stainless steel. It is a dual rear exiting system with a 4” Borla embossed single round, rolled edge, angle cut tip at each exit. This system consists of two 2.25” inlet pipe leading to a 19” long, 10” wide oval muffler. Exiting the muffler are two 2.25” pipes connecting to two 16” long, 5” diameter resonator mufflers. Following the resonators are two 2.25” over axle pipes leading to a single 10” long, 10” wide oval rear muffler. R&D testing has shown that our system flows up to 428.3 cfm more than the factory exhaust (for a total flow of 885.9 cfm @ 70psi) and has shown an increase of up to 14 additional horsepower and 11 ft. lbs. of torque. The Systems weights in at 51 lbs. while the factory system weights in at 74 lbs. This system averages 4 dba louder than the factory exhaust.
Borla G35 03-06 Sedan True Dual Exhaust System, $870.00 Shipped
Borla 17221 G35 Stainless Steel Headers, $663.00 Shipped
Borla G35 True Dual Exhaust / Strup Header Combo, $1,720.00 Shipped
Old Dec 30, 2009 | 01:35 PM
Mike@CZP's Avatar
bumped!!
Old Jan 5, 2010 | 05:25 PM
Mike@CZP's Avatar
bumped!!
Old Jan 6, 2010 | 04:24 PM
Mike@CZP's Avatar
bumped!!
Old Jan 8, 2010 | 04:41 PM
Mike@CZP's Avatar
bumped!!
Old Jan 11, 2010 | 03:34 PM
Mike@CZP's Avatar
bumped!!
Old Jan 14, 2010 | 04:54 PM
Mike@CZP's Avatar
bumped!!
Old Jan 15, 2010 | 03:51 PM
Mike@CZP's Avatar
bumped!!
Old Jan 19, 2010 | 03:38 PM
Mike@CZP's Avatar
bumped!!
Old Jan 22, 2010 | 03:55 PM
Mike@CZP's Avatar
bumped!!
Old Jan 25, 2010 | 03:49 PM
Mike@CZP's Avatar
bumped!!
Old Jan 27, 2010 | 03:30 PM
Mike@CZP's Avatar
bumped!!
Old Jan 29, 2010 | 12:12 PM
Mike@CZP's Avatar
bumped!!
Old Feb 1, 2010 | 03:25 PM
Mike@CZP's Avatar
bumped!!
Old Feb 3, 2010 | 03:54 PM
Mike@CZP's Avatar
All PM's answered
