Exhaust-Vendor Includes Headers, Test Pipes, Y-Pipes, High Flow cats and Cat-back Systems
▲▲▲Megan Racing Exhaust Products: Catbacks, Ypipes, Test Pipes, and more!▲▲▲
Old Aug 25, 2010 | 08:35 AM
Marinelli Motorsports's Avatar
OE-RS Series:
Megan Racing OE-RS series cat backs are based on factory style, with bigger piping, OEM style polished mufflers and quiet sound. The cat back system is made stainless steel. All pipiing are mandrel bent with a high polished finish. Exhaust system comes with all the necessary hardware needed for a direct bolt on installation. Improves HP with minimal noise.
G35 03-07 Coupe:
- Dual 4" burnt tips
- T304 Stainless Steel
- 3" piping
- Direct bolt-on applicatioin
Also in New Black Series!!!
G35 03-06 Sedan:
- 3" piping, dual 3" tips
- Made from T-304 Stainless steel material.
Drift Spec Series:
One of Megan Racing s strongest products, the Cat-Back System is made of SUS-304 Stainless Steel with a fully polished surface, CNC machined flanges and mandrel bends. Its aggressive styling, and deep, strong tone are just part of the MR Cat-Back characteristics. It also serves to improve horsepower, torque and overall performance with its straight-through design. The exhaust systems have 2.5Ħħ piping and 3Ħħ piping for certain forced induction models. Finished with a tip that is designed to increase the scavenging effect and achieve maximum performance, while adding a perfect match on exterior styling as well. As a direct bolt on, each Cat-Back comes with a 12-Month warranty.
Note: Exhaust is designed for 350Z. It requires a separate purchase of an extender to make it work.- 4.5" Flat tip with removable double-layer silencer, 3" piping
- 100% stainless steel with polish finish
- Producing strong, deep and noticeable sound
- Gain more horse power, faster response, averaging 10-15 extra hp
- Comes with gaskets
- Warranty included
- Single Exhaust
Resonated Test Pipes:
Megan Racing Stainless Steel Down-pipes are made of the same high-quality SUS-304 that is utilized in our Headers and Turbo Manifolds for extreme durability and resistance to corrosion and cracking. The missing component between any Header/Manifold and your Cat-Back system, these Down-pipes will complete the high-flow exhaust system desired for the performance of your vehicle. With a noticeable power gain throughout the rev-range and a polished finish, these are a perfect addition for any performance vehicle. (NOTE: For off-road use only, not intended for use on public highways.)
These cat-delete pipes are test-pipes with built-in resonators. They are able to give a deeper sound, improving the exhaust tone.
- 100% SUS-304 Stainless Steel Piping
- Built-in resonators and flex pipes
- ID 2.25", OD 2.5"
- Direct-bolt on, includes gaskets and hardware
Y-Pipe:
The Infinity G35 and Nissan 350Z are high-end performance machines, boasting the VQ35DE V6 Engine that easily pulls these cars through the highest demands. Because they are at the fore-front of automotive technology, many aspects of the cars performance have grown increasingly complicated. Modifying simple things such as the vehicle's exhaust system, becomes a daunting task that can become pricey. Due to the complexity of the bends, flanges and welds in the OEM Y-Pipe, Megan Racing has decided to manufacture a direct bolt-on Y-Pipe for the 350Z and G35.
The Y-Pipe features two High-Flow flex pipes to reduce the interior noise resonance without sacrificing performance while the Polished T-304 Stainless Steel construction offers a show-car look and long lasting durability.
The inlets are 2.5" that follow through with individual pipes until they converge at the Cat-Back system with a 3" Flat-Flange to provide a secure and tight seal every time.
- 100% T-304 Stainless Steel with computerized mandrel-bends
- CNC-machined flanges for strong solid support
- TIG-welded for strength and durability
- 3-stage polish for a mirror-like finish
- Straight-through design and bolt-on installation
Headers:
Megan Racing Stainless Steel Headers are made of thick T-304 Stainless Steel and are mandrel-bent to form and fit your particular application with the best performance results possible while the thick flanges and strong welds prevent cracking and offer long-lasting durability. These Headers and Turbo Manifolds help your engine maximize its performance by allowing the exhaust gasses to flow more efficiently to gain power and performance. (NOTE: For off-road use only, not intended for use on public highways.)
6-2 primary piping design
- 2.25" inner diameter outlet
- 100% T-304 Stainless Steel with Polished Finish
- Direct bolt-on, increased exhaust flow for improved engine performance
1 piece design header w/ Test pipe
- 6-2 piping configuration
- 2.25" Inner Diameter Outlet
- 100% T-304 Stainless Steel with Polished finish
- Increase exhaust flow and engine performance
Please PM me with location for best pricing!
Exhaust Packages are offered as well too!!!
Old Aug 25, 2010 | 01:51 PM
Pics Added!
Old Aug 25, 2010 | 05:49 PM
All PMs replied!!!
Old Aug 26, 2010 | 10:07 PM
All PMs replied!!!
Old Aug 28, 2010 | 12:12 PM
All PMs replied!!!
Old Aug 29, 2010 | 11:29 AM
Bump!!!
Old Aug 30, 2010 | 06:48 PM
Bump!!!
Old Aug 31, 2010 | 09:36 AM
All PMs replied!!!
Old Aug 31, 2010 | 07:20 PM
To the Top!!!
Old Sep 2, 2010 | 06:18 PM
Bump!!!
Old Sep 3, 2010 | 07:59 PM
All PMs replied!!!
Orders shipped!!!
Old Sep 4, 2010 | 08:17 AM
All PMs replied!!!
Old Sep 6, 2010 | 09:10 AM
Labor Day bump!!!
Old Sep 7, 2010 | 07:11 PM
All PMs replied!!!
Old Sep 7, 2010 | 07:28 PM
DEEZBLUBALLZ's Avatar
headers shipped to 68114. 05G coupe
Not the one piece race one, the regular one.
thanks
