WTB: 04 coupe door lock actuator
Old Jul 15, 2014 | 02:32 PM
CharlesCather's Avatar
Im looking for the 04 coupe passenger door lock actuator kit, can be used as long as it works perfectly. message me on here or text me at 850-357-3719
Old Jul 16, 2014 | 04:19 AM
mindtrip's Avatar
Here is a link to a aftermarket door lock repair kit. Me and my boy fixed both of his doors with this kit. http://www.ebay.com/itm/281372452940...84.m1555.l2649 after you order they send you a link to a video so you can see on done.Best part its under 50 bucks
Old Jul 16, 2014 | 01:28 PM
Do you know a DIY on this? I contacted the gentleman on Ebay and he sent me a link but it was unclear about how to hook up the rod purchased to the door actuator wire that was being cut from the cable... Sorry I'm a noob and want to make sure I can do it before I get started.
Old Jul 17, 2014 | 02:16 AM
mindtrip's Avatar
Ok the rod is hooked up with the clamp that is supplied with the actuator.Now here is the tricky part of the install ,you have to take the door lock cable and cut about 2-3 inches of the insulation off. then cut the cable that's surrounding the inner core of the cable. Now be care full not to damage the inner core.once you have the door panel off you can see what i'm taking about on the door lock cable.the inner core is what makes the door lock and unlock.once all that is done use the clamp and the special u shaped insert that's in the cable kit. Without it the clamp will not hold on to the cable you just exposed.Once all that's done and you mount it wire it up. he even tells you the colors and where to get them.try it before you put the panel back on to make sure that lock and unlock is right .After all is done you just saved yourself over 400 bucks because the dealer charges almost 500 bucks to replace 1 door lock actuator. So well worth buying the kit and doing it yourself.
mike730
Jan 12, 2018 04:25 PM
xluke
Jul 30, 2016 01:48 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
