Project SWAP !!!
Old Jul 3, 2006 | 08:33 AM
  #106
Audible Mayhem's Avatar
i will be tuning it all week and hopefully take a nice "baby run" at the track this friday. not on my slicks, just the 265 DRs that on there now. i just want to see about what it will do before i slap the slicks on there....
maybe slicks next week though, i am about to take the first drive with more than 4.5 psi!!!!!
this might be scary!!!
first low boost at 8.5 then high at 12.5 then i will work from there
Old Jul 3, 2006 | 10:38 AM
  #107
escobar929's Avatar
^^^that will be a sweet run, take the vid cam w/ you
Old Jul 3, 2006 | 02:21 PM
  #108
it was running lean but i was driving around on 7 psi. jesus!!! its so sick, i am going to richen it all up right now and take it out for some tuning runs...
Old Jul 5, 2006 | 10:13 PM
  #109
cj350's Avatar
What did you run at the track today ???
Old Jul 6, 2006 | 11:52 PM
  #110
sorry man, didnt get a chance to tune it at all...
tomorrow night is not looking good either, so its looking like next week...
running around on 12 psi right now though.... hehehe
Old Jul 9, 2006 | 03:18 PM
  #111
KenK2's Avatar
The Pole
Jeremy..
Congrats on the swap.. That is soooooo sick bro, I am soo jealous!
Good luck at the track..
Old Jul 9, 2006 | 03:30 PM
  #112
thanks man, just got my HKS DLI II and just need to throw it in, car is running great!!!
Old Jul 9, 2006 | 03:35 PM
  #113
KenK2's Avatar
The Pole
Take me to class.. What is that??
Old Jul 9, 2006 | 03:36 PM
  #114
KenK2's Avatar
The Pole
Heres what I got off the website.. Figured you could put it in English for me
The Twin Power ignition amplifier incorporates both the CDI and transistor method ignition to provide optimum spark duration and maximum voltage output, resulting in crisper throttle response and a smoother engine powerband. The CDI method, capacity discharge ignition, provides maximum voltage by transferring all stored energy in the capacitor to the ignition coil so that the ignition current can buildup quickly, thus making the Twin Power very effective in the higher revs where a normal spark would tend to diminish. This strong rapid spark prevents the high rpm ignition miss that reduces peak power. The transistorized method generates high voltage by using transistors to cut off current to the coil, thus allowing for a long energy discharge. This longer spark duration allows the Twin Power to improve lower RPM throttle response and torque. The combination of the CDI and the transistor method incorporates two distinct systems into one high performance unit, hence the designation of Twin Power. The Twin Power produces a spark output that is typically 1.5-2.5 stronger than of the stock ignition system and consumes about 35% less power input than other ignition amplifiers. Each compact and attractive Twin power unit is constructed of durable anodized aluminum and sealed to prevent corrosion from moisture. General wiring harnesses are included in each unit to aid in installation and mounting. Vehicle Specific wiring harnesses are also available for certain models to further aid in installations that require intricate integration.(CARB E.O. # D-186-22)
Old Jul 9, 2006 | 04:14 PM
  #115
basically its an ignition system that amplifies the spark going to the the coils so you can run larger gaps on your plugs. more spark more torque more power...
Old Jul 9, 2006 | 07:10 PM
  #116
KenK2's Avatar
The Pole
Interesting... Would you install that system if you were FI ONLY, or would it be beneficial if you were NA??
Old Jul 9, 2006 | 08:41 PM
  #117
well its 600 dollars and i would even bother unless i was boosted. the benefits
NA would be minimal, a lot of boosted VQs have to set the gap to .024-.026 because of problems putting out the spark, this will solve it...
Old Jul 9, 2006 | 10:38 PM
  #118
KenK2's Avatar
The Pole
Good to know.. Good post, thanks!
Marlin84
Apr 1, 2020 12:52 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
doakley92
Sep 25, 2015 12:58 PM
