Need quick answer on tire question
Old Oct 4, 2006 | 02:20 PM
Dakkerz's Avatar
I need some new tires for the oem 19's I just got, asap. The person I got them from just put on a brand new Toyo T1R 255/40/19 for the rear.
I ordered a set of Toyo T1R 225/40/19 for the fronts but just found out (after waiting a week with no response ) that they are on back order for at least another 2 weeks. My question is can I run 245/35/19 on the fronts instead or will they not match up well with the 255/40/19 in the rear.
Thanks in advance everyone.
-Dak
Old Oct 4, 2006 | 02:35 PM
WILD121's Avatar
Talk to Dan he can get you tires faster. Im think
Old Oct 4, 2006 | 02:36 PM
Dakkerz's Avatar
Cool thanks. What about the tire size issue, will I be okay if I HAVE to get the 245's?
Old Oct 4, 2006 | 06:14 PM
Gilley's Avatar
The diameter of the T1R is as follows:
Front
225/40ZR19 26.1 inches
245/35ZR19 25.8 inches
Rear
255/40ZR19 27.0 inches
The stock tire diameters (19 inch Bridgestone RE050) are:
Front
225/40R19 26.1 inches
Rear
245/40R19 26.9 inches
So to answer your question, you could use the 245/35 since it is only .3 inches smaller in diameter than stock, or 1.3% smaller in diameter.
Incidentally, your rear tire is 1.2% larger diameter.
Generally, you want to keep the replacement tires within 3% of OEM.
Play around with different tire sizes here:
http://www.miata.net/garage/tirecalc.html
Old Oct 4, 2006 | 07:13 PM
Dakkerz's Avatar
Thanks Gilley, that response and link were extremely helpful. I was also able to get a hold of Dan and he's looking into ordering some tires for me.
You always get the answers you need from this board, especially from FGC members.
Thanks again everyone.
Old Oct 4, 2006 | 11:28 PM
ZUL8R's Avatar
Tirerack is running a special on the Bridgestone RE50's $141 each instead of $262 each.
http://www.tirerack.com/tires/Compar...13&RunFlat=All
Old Oct 4, 2006 | 11:33 PM
SFLG35's Avatar
FGC President
damn thats pretty good deal
i usually have teh 245/35/19 instock so i can probably get you those quicker.
i will check in teh morning if the 225/40/19 are instock or not and what kinda wait it is on those and let you know
Old Oct 5, 2006 | 12:45 AM
ZUL8R's Avatar
Yeah, I got a pair for my new rims
Old Oct 5, 2006 | 12:59 AM
Dakkerz's Avatar
well if its not going to be a huge difference running 245/35/19 and that's what you can get the quickest I'll go with those. But I guess we'll see what happens tomorrow.
Thanks.
Old Oct 5, 2006 | 07:23 PM
Finiti35's Avatar
FGC South Florida BOD
Get the 245's and get rid of that understeer. Leave the 225's to Accords and Camrys to run.
Old Oct 5, 2006 | 07:57 PM
WILD121's Avatar
The only problem i dont like about these tires is they will only last 10k max. I went through these tires in 8k. Good deal but they dont last long enough IMHO. I would rather pay more for a tire like the T1R and have it last 18k-25k. Im going on 17K on my T1Rs and I can push it for another 4k maybe more.
Old Oct 5, 2006 | 10:53 PM
escobar929's Avatar
well said!
Old Oct 6, 2006 | 12:21 AM
Dakkerz's Avatar
Yeah it looks like I'm going with the 245's since he can get them the quickest.
Old Oct 10, 2006 | 04:02 PM
Dakkerz's Avatar
Ok I ended up getting the 245/35/19's and had them mounted yesterday. They feel a lot better than the worn out oem bridgestones.
Thanks again SFLG35 for coming through with those on short notice.
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
Soumilg
Jul 18, 2015 12:33 PM
