TN times
Old Mar 24, 2007 | 04:24 PM
Nismo G's Avatar
Originally Posted by 98intrigue
I only managed a 2.0 60' on the 265/40/18 BFG drag radials that are mounted on my stock 18s. I know it's bad... would do 2.0 60' times on my 19" street tires. I just need to learn how to launch on them and what PSI to set them at.
Get over here to bradenton i want to see it go.
-sean
Old Mar 24, 2007 | 04:33 PM
98intrigue's Avatar
Originally Posted by _jb
Ryan, What engine management system are you using?
Did you keep your UTEC? If so, I'm curious how you have your Innovate WB gauge hooked up? I heard it was not compatible with the TXS Tuner box.
Yes, I still have the Utec. I heard the same thing. I asked Jeremy abotu it and he explaind it to me, but I forgot...so I'll leave that for Jeremy or Andrew to answer. All I know is that Jeremy has the tuner box, so I don't have to worry about it.
Old Mar 24, 2007 | 04:40 PM
WILD121's Avatar
My car has a extremely conservative tune. I made 343rwhp/381rwtq. I don't think your friend would run an 11.9 with that power. The car has much more in it, but without a return fuel system...pushing it for more power would not be safe. With my car having over 65,000 miles and it being my only car, safety is my #1 concern.
Safety Safety Safety
Old Mar 24, 2007 | 10:51 PM
QuadCam's Avatar
If you have a TXS Tuner wideband, there is a way to get the innovate display to display the Wideband reading, but............
you can't use the innovate wideband sensor/gauge to hook up to the UTEC. There is some aftermarket software that'll allow you to simultaneously log them together, but the best way is to use the TXS Tuner connected to the UTEC.
In my car, I have the Tuner tucked up high bedhind the dash (can't see it), so I figured out a way to get the output of the Tuner to be displayed on a gauge. I use the dynotunenitrous.com digital gauges, and it works flawlessly. I tis mounted in my ashtray, next to my digital fuel pressure gauge, and they both close up in the ashtray if I want to hide the gauges!!!
Old Mar 26, 2007 | 12:59 AM
_jb's Avatar
_jb
Photographer
Maybe Jeremy used his tuner kit to tune your G and then removed it and installed the Innovate gauge.
In any event, the Innovate gauge is pretty sweet. I know you're enjoying it and your whole G. It has to be like a new car!!!
Old Mar 26, 2007 | 01:09 AM
_jb's Avatar
_jb
Photographer
Thanks for the info! I went back and read a couple of your posts about adapting gauges to the tuner kit. You did some nice detective work there.
Would it be possible to use the Cipher software to tune a UTEC? It seems to give the same info as the TXS Tuner Kit and could be easily removed when not in use... plus it has a nice interface.
Old Mar 26, 2007 | 08:14 AM
Audible Mayhem's Avatar
if you arent on a dyno or at the track, tuning it on the street is just guess work. i have been using a tuner wideband on all the utec vehicles i tune at my shop, its much easier and datalogs it all together.
Old Mar 29, 2007 | 11:59 PM
QuadCam's Avatar
exactly...the only way to street tune your UTEC is with the Tuner hooked up too. any other way and you won't know exactly what what was happening with the A:F at that time.
Old Mar 30, 2007 | 12:42 AM
w0ady's Avatar
fgc moderator
you better tell matt that. i hear his neighbors are getting tired of seeing him drive up and down the block.
Old Mar 30, 2007 | 01:19 AM
2slo2bfurious's Avatar
lol, I think my neighbors love me for driving around and around and around my block at 3am tuning Must be fun to have your own dyno huh??
Old Mar 30, 2007 | 10:44 AM
WILD121's Avatar
I need a dyno
Old Mar 30, 2007 | 11:36 AM
_jb's Avatar
_jb
Photographer
I understand. I still plan on letting you (Jeremy) install the UTEC and tune it on your dyno... that hasn't changed...
But I'd like to be able to see how the A/F and things change over time after the tune... and maybe make a map similar to one that Jeremy makes for hotter Summer times... or maybe colder Winter times, if I get it installed in the Summer... I like to see how things work, so I'd probably want to get the Tuner Kit, but I though it might be cool to use the Cipher instead if I could get the same info from it, because I already have one... and using the Cipher instead of the Tuner Kit would free up an OS spot for an Innovate A/F gauge that I'd also like to use... Just trying to figure out what I want to do...
When you install a UTEC for someone, and tune it for them, do they usually buy a Tuner Kit, or, do you use your Tuner Kit and then remove it after the tune?
Old Mar 30, 2007 | 11:37 AM
AboostedG's Avatar
Originally Posted by WILD121
I need a dyno
What's the point, your car is still going to be slow. I mean Katies...
Old Mar 31, 2007 | 03:25 PM
98intrigue's Avatar
Yup. Jeremy uses his Tuner Pro on anyone's car who has a Utec.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
Joshua615
Aug 31, 2015 12:29 AM
