Chroming TPS??
Old Mar 29, 2007 | 04:24 PM
Gilley's Avatar
^ That's not the TPS.
Old Mar 29, 2007 | 06:48 PM
_jb's Avatar
_jb
Photographer
Here's a picture of the Tire Pressure Sensors.
Make sure you keep each TPS where it was originally located on your G.
The outer sleeve threads over the valve stem to hold the inner part of the TPM in place. That's what you want to polish. Maybe you could just loosen one and take it off the wheel without causing a problem. You could polish it and then put it back on. The air pressure inside the tire should keep the TPS from falling out... I think...
Old Mar 30, 2007 | 07:46 PM
chobble19's Avatar
thanks jb...just need to find someone to polish them now lol
Old Mar 30, 2007 | 11:13 PM
Gilley's Avatar
Do you have a drill? Do it yourself.
Get a 5 inch buffing pad from Home Depot, Lowes, Ace Hardware, or the auto parts store. A small buffing wheel from Ace Hardware would be better.
Get some 1500 or so grit wet sand paper and sand the nuts smooth.
Use some Blue Magic metal polish, or something similar, and polishi it with the buffing wheel until it's polished.
Old Mar 31, 2007 | 11:08 AM
chobble19's Avatar
thanks for the info gilley maybe ill give it a try. ive never tried to polish something out before but we'll see. i post what the outcome is
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
itgogitrev
Sep 25, 2015 10:28 AM
rollaspeed1
Sep 16, 2015 03:10 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
