brake issues
Old Jul 23, 2007 | 01:28 PM
Gilley's Avatar
I got my Brembo and non-Brembo rotors turned at PepBoys for $6 each if you take them in. They are simple to remove.
Remove the wheels. Remove the 2 bolts fastening the caliper to the hub/spindle (whatever it's called), slide rotor off the studs. Repeat in reverse order to install rotors. The front bolts are 22mm and I think the rear bolts are 19mm.
Old Jul 23, 2007 | 01:35 PM
w0ady's Avatar
fgc moderator
i need stands to take them off myself. thats the nice part about a house with a garage.
Old Jul 23, 2007 | 02:22 PM
Gilley's Avatar
Yes, a garage is nice to work in.
Old Jul 23, 2007 | 02:29 PM
w0ady's Avatar
fgc moderator
Originally Posted by chobble19
lmk how that goes...just to let u know i got quoted (copied from pm):
for the track setup, it is going to be $345 (discounted 20%) + $70 for pads + $47 (shipping). Grand total is $462.
for the non track it is $272 (discounted 20%) +$70 for pads +$47 shipping. The grand total is $389.
http://store.r1concepts.com/Brake%20.../Infiniti/G35/
what was the 20% discount for alex?
Old Jul 23, 2007 | 09:59 PM
chobble19's Avatar
i think its just their special pricing on driver.. i thought they had a group buy or something but i couldnt find it
Old Jul 24, 2007 | 08:11 PM
r1concepts's Avatar
Are you guys ready for another one??
Old Jul 24, 2007 | 08:56 PM
w0ady's Avatar
fgc moderator
i plan on getting my rotors turned to see if that solves the issue. if not, im definitely interested in 1 of your sets. whats the pros/cons of the 2 setups if you dont mind?
Old Jul 25, 2007 | 11:55 AM
r1concepts's Avatar
Here is the link of the 2. http://www.r1concepts.com/performance.html
Old Aug 7, 2007 | 11:56 AM
w0ady's Avatar
fgc moderator
update: check 1 of my rotors yesterday and it was definitely out of spec. taking them to get turned today and we'll see how long that lasts. our stock rotors are pretty thick so i dont see a problem getting them back in spec. i figure if they go out again, then ill go ahead and do a full upgrade.
Old Aug 7, 2007 | 12:20 PM
r10apple's Avatar
I should get my new Hawk pads and Racing Brake drilled/slotted rotors Friday and have them on Saturday. You should be able to check them out on the 25th if you are still having issues...
Old Aug 7, 2007 | 12:48 PM
w0ady's Avatar
fgc moderator
thanks cass. ill definitely do that.
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
Terry_G35
May 9, 2020 01:39 AM
derres
Aug 28, 2015 03:27 PM
itschuckster
Jul 25, 2015 08:07 AM
Lsantana757
Jul 20, 2015 09:08 AM
