MREV2 + Motordyne 5/16"! What a combo!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Aug 18, 2007 | 09:42 AM
g35sedan5at's Avatar
i run my JWT popcharger with no heatshield and not connected to the long black thing that acts as a guide for air through the grill and it most def pulls harder. and i can assure that i have hotter weather than most of u on this forum.lol. every said no heatsheild id lose power but it doesnt seem so.
Old Aug 18, 2007 | 11:56 AM
Hydrazine's Avatar
I tested the effect of hot to cold air ingestion on the dyno and it made a big difference.
Using a trash can full of ice cubes and a nework of dryer ducting I was able to supply the intake with cold air at about 45' F. By mixing the cold air and with hot air from behind the radiator I was able to vary the mixture to vary the air temperature from ~ 50'F to 120'F.
I tested from lowest to highest in 10' F increments to see the effect on the power curve. And it really made a big difference. 10-15 HP across most of the curve.
Also note, at low temperatures the car ran leaner than normal and at high temperatures it began to run rich.
Old Aug 18, 2007 | 02:25 PM
TIAN's Avatar
Hold The Line
Originally Posted by battlebuddyP
the rev up how do you know if ur engine is the rev up im not sure?
2005 and up - Rev-up
Old Aug 18, 2007 | 02:40 PM
highroller087's Avatar
i'm thinking about putting MOTORDYNE ISO THERMAL 5/16 PLENUM SPACER KIT into my G35 Coupe 5AT.. should I also put my stock intake back? I have a Stillen w/ Z Tube
and also i've heard its waste of money if I put MREV2 on??
Old Aug 18, 2007 | 04:56 PM
battlebuddyP's Avatar
how old is your stillen and z tube miles... if u switch back out how much would u take for it wat all do u have still??
Old Aug 19, 2007 | 01:19 AM
Hydrazine's Avatar
No, not at all. The Stillen well works well with the MREV2.
Keep your Stillen.
Old Aug 19, 2007 | 09:41 AM
Ramon's Avatar
Originally Posted by Hydrazine
I've tested several of the long tube CAI's on the dyno and they lose power every time.
And its not just with a spacer. They lose about 3+HP no matter what you hook them up to.
I see! Now, let's say I get rid of my CAI and get a Z-tube with a K&N filter. Although I was losing about 3+HP as you have mentioned, will I be able to tell the difference in gains with the Z-tube once I start driving the car? Is it that noticeable where people can really say "My car does feel faster!".
I'm EXTREMELY happy with the MREV2 + Spacer. But if you tell me that they will work much better if I get rid of my CAI, then I probably will get a Z-tube and K&N filter. Thank you in advance.
Old Aug 19, 2007 | 07:31 PM
Hydrazine's Avatar
You know what.... I've never dynod a K&N intake.
I say take it to Performance Factory and get a baseline dyno. Remove the long tube CAI and dyno it again without removing the car from the dyno.
Then post you results here.
A lot of people would like to see your results.
Old Sep 7, 2007 | 11:03 AM
kjgspot's Avatar
hey was up guys... im new to this thread... just wanted to know i have a 04 6speed what would be the best for my car, get a aftermarket intake or just keep it factory and change it to he z tube and k&n filter . i was thinking about go kinetix but from reading this thread i guess the z-tube and k&n would be the way...
i need you knowledge..
Old Oct 30, 2007 | 05:00 AM
RichardxG35's Avatar
So let me make sure i get this correct the stillen and/or jwt will be better to use than wat i was going to buy aem?
trent don't get the AEM.. i use to have one an sold it.. get the stillen or pop charger
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
bigmike
Sep 17, 2015 01:58 PM
