Suspension Question Guys....
Old Oct 30, 2007 | 06:43 PM
blkonblk17's Avatar
Im about to buy a g35 coupe. Is it normal for the front tires to have un even tire wear. The person I am buying them from says its normal in g35's. Should I be concerned?
Thanks
PS: vehicle has factory suspension and wheels
Old Oct 30, 2007 | 08:08 PM
Kidcane's Avatar
Not normal for me.
Old Oct 30, 2007 | 08:14 PM
StreetChase's Avatar
2 questions:
1. How bad is the wear? on the inside or outside of tire?
2. Did the previous owner have an aftermarket suspension and then just put it back to stock to sell?? If this is the case his allignment may have been off.
but no, that is not normal
Old Oct 30, 2007 | 08:21 PM
Gilley's Avatar
It depends on the wear pattern. Some inside tire wear is normal for some cars. It can be remedied with camber kits.
Old Oct 30, 2007 | 08:52 PM
blkonblk17's Avatar
Originally Posted by StreetChase
2 questions:
can see noticible difference/its on the inside..he says you would most likely need to change the tires every 16k. this is only for the front tires the rears have no problem. he is the only owner and states has never had an aftermarket part installed.
Old Oct 30, 2007 | 09:07 PM
thats a little on the bad side but i wouldnt use that as a reason not to buy the car. that can be fixed by first getting alignment and if that still doesnt help get a front camber kit and your problem is solved
Old Oct 30, 2007 | 10:00 PM
blkonblk17's Avatar
thanks
Old Oct 31, 2007 | 09:08 AM
CleanGThree5's Avatar
just buy my car and avoid buying some guys G that needs an alignment lol.
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
