Sarasota/Venice - 04/26 spring install?!
Old Apr 28, 2008 | 07:58 AM
Dakkerz's Avatar
Originally Posted by TheDrov
Yeah man I got it done and that was me on clark road . Kt and I had to take it out for a spin and get some food. Those springs are amazing btw I am suprised no one else has gotten them, I seriously doubt that it is possible to get a better ride with a 1+ inch drop and only replacing the springs. It's alright that you had to take off man I still appreciate you coming down and helping me out! KT ordered some F-sport Springs for his IS and sais to me 'man you are going to help me install them right?' and I said ummmm. No take it to a shop
Haha I thought that was you on clark. I was at the Starbucks by the BMW dealership. Well I'm glad everything worked out good even though they gave you the wrong spring compressor . At least you found a new way to install springs though .
Old Apr 28, 2008 | 08:05 AM
TheDrov's Avatar
Yeah, I was hoping my suspension wasn't going to fall off the car after using my innovative spring install method .
Old Apr 28, 2008 | 12:30 PM
B B S's Avatar
So how hard was it? I'm waiting for my SPC rear arms to come in. Did you have to drill a bigger hole to fit the rear SPC bolt?
Old Apr 28, 2008 | 01:54 PM
TheDrov's Avatar
Didn't need a Toe bolt. The stock toe with aftermarket camber arms was enough to get the rear camber/toe perfect. The springs were pretty hard but we ran into some issues that you would probably not have to deal with as long as you make sure the guy gives you the right spring compressor.
Old Apr 28, 2008 | 01:57 PM
Dakkerz's Avatar
Damn discount auto employee
Old Apr 30, 2008 | 01:24 AM
B B S's Avatar
Just finished my front spring install. Took about 2 1/2hours for the front left, because I was figuring everything out. And the front right only took about 45min. Pretty easy once you get the hang of it.
Old Apr 30, 2008 | 10:17 PM
B B S's Avatar
Rear finished last night as well. Not hard at all, only problem I had was lining the screw up. Installed S-tech, not happy about the drop at all. To minimal.
Old Apr 30, 2008 | 11:00 PM
TheDrov's Avatar
That's good you didn't have as much trouble as I did . That sucks you aren't happy with the drop though. If you dislike it enough to get different springs you should seriously consider Vogtland springs. These things ride amazing and the drop is perfect imo. 1.4 all around. I will take pics tommorow and put them up.
Old Apr 30, 2008 | 11:06 PM
Dakkerz's Avatar
Give the spring some time to settle before making a decision.
Old May 1, 2008 | 01:31 AM
B B S's Avatar
Bought them used, so I'm assuming they had their time to settle.
Old May 1, 2008 | 11:33 AM
iamericgee's Avatar
if you want a lower drop get some eibach sportline springs !! thats what adrian has on his ip g35 !
snic09
Nov 8, 2017 01:46 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
EPG35
Aug 16, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
