dm2 engine pics
The front of the engine looks great without the upper heater hose running across. As far as the wire tuck goes, you can make a big difference just by tucking the harness behind the oil filler.
we have clearance issues with running the harness behind the filler neck. Our upper and lower collectors are cut so much the fuel rails barely have clearance. No room for the harness.
