Osiris Tune Twin Turbo Greddy 404HP
Old Dec 31, 2008 | 07:29 PM
s&R Performance's Avatar
They said it couldn't be done. We just finished tuning a twin set up on 03 350z stock block and 6.952lb's of boost and made 404 to the wheels. We would have made more but ran out of injector.
Who Next!!!
This ride belongs to Mr. Zoleman
Old Dec 31, 2008 | 07:36 PM
Invalid_User's Avatar
very interesting
Old Dec 31, 2008 | 08:08 PM
Evil Wayzz's Avatar
Is this a New Roller Coster aww MAN can't wait to RIDE IT.
Old Dec 31, 2008 | 09:19 PM
w0ady's Avatar
fgc moderator
pretty smooth graph. sorry for the noob question, but how does a dynomite compare to a dyno dynamics or dynojet?
Old Dec 31, 2008 | 11:04 PM
That is a hard question without typing 6 page report. A dyno is just a tool to help tune a car.
No matter what dyno you are on just make sure you record your first pull and build from there.
Old Dec 31, 2008 | 11:14 PM
lekker_droom's Avatar
Is 400hp really that good for a TT + Osiris car? Sorry for the question but I'm really curious?
Old Jan 1, 2009 | 01:15 AM
Sbeck's Avatar
On that amount of boost with a stock block i think so
Old Jan 1, 2009 | 02:02 AM
_jb's Avatar
_jb
Photographer
The issue isn't really making maximum horsepower on a stock bottom end... it's on making good usable horsepower that's fun to drive and keeping the engine safely together.
Another nice dyno printout... Good curves on the hp and torque... nice flat line on the 02... looks good!
Old Jan 1, 2009 | 09:07 AM
w0ady's Avatar
fgc moderator
no you're right, i should have expected as much. do you happen to have a baseline of the car before the kit?
Old Jan 1, 2009 | 10:25 AM
For 7lbs that is great. If I had 600cc injectors I would have made 430.
Old Jan 1, 2009 | 10:27 AM
No...But I have dyno so many of them stock and seen around 250 to 260 and some as low as 230
Old Jan 1, 2009 | 08:28 PM
undefeated350gt's Avatar
Osiris tune is a reflash program for the OEM edu right? and if so that is pretty good for just seven pounds of boost.
Old Jan 1, 2009 | 08:35 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
wow.. only on 7lbs on stock ecu.. really good work
Old Jan 2, 2009 | 04:11 PM
escobar929's Avatar
im assuming the green line is AFR, wouldnt 12.75 be way too lean at WOT, thought it was best around 11.3-11.5
could it be the location of the sniffer? and its really 11.7?
Old Jan 2, 2009 | 04:50 PM
The location of the sniffer is about .5. This was just a glory pass on the Dyno. We just simply ran out of injector. We back it back down to waste gate pressure.
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
