Engine Compression Ratio
Old May 8, 2009 | 03:43 AM
Amerbfr's Avatar
Does anyone know what the Compression ratio is in a 05 3.5L G35?
I see Infinity says to use 93 octane and wondered if the compression ratio is really high enough to warrant that...
Anybody use Mid grade or cheap stuff in their wips?
Just wandering...
Old May 8, 2009 | 07:56 AM
Jeremy@Altered's Avatar
10.3 is stock. You can run 87 in there if you want but the car will feel like crap. The knock sensor will pick up knock and retard the timing accordingly.
Old May 8, 2009 | 08:00 AM
escobar929's Avatar
Infinity huh?
i didnt know you could use 93 octane on speakers
Old May 8, 2009 | 08:25 AM
Sen's Avatar
Sen
Old May 8, 2009 | 09:04 AM
w0ady's Avatar
fgc moderator
use 93. oil, gas and tires are 3 things i dont cheap out on.
Old May 8, 2009 | 09:17 AM
But beer and hookers you aim for the best deal huh?
Old May 8, 2009 | 07:41 PM
Amerbfr's Avatar
I wasn't trying to cheap out... Just wanted to know what the compression ratio was to see if it justified running High octane petro. I see it does... will continue to run high test.
Old May 9, 2009 | 06:45 PM
w0ady's Avatar
fgc moderator
h00ters/hookers, same difference.
Freeman186
Sep 6, 2023 10:07 AM
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Joe Gargano
Sep 18, 2015 11:17 AM
