car trouble
Old Jun 7, 2009 | 09:46 PM
ltorres781's Avatar
car trouble
hey guyz.. i needed ur opinion.. about 3 months ago i got an aftermarket clutch installed at courtesy infiniti in tampa... shorty after i start gettin problems with my gears.. when the gear box is hot and i stop at a light or pull into a parkin spot, i sometimes have to force it into first.. or force it into reverse .. im thinkin its my syncros.. so i've takin it back to courtesy like 4 times.. and they keep tellin me they cant recreate it.. they keep tellin me they want to recreate it before they open it up becuz they dont wanna blow 5,000 on a new tranny and then thatz not the problem.. so i dont know what else to do... im startin to get pissed wit the whole ****in situation.. i've talked to one of the service guys there that im cool with.. and he sayz they're good for **** like that their.. they keep prolongin things so eventually ur warranty expires and u pay for everythin out of pocket... any advice?
Old Jun 7, 2009 | 11:16 PM
iamericgee's Avatar
go try lokey in clearwater and talk to christian !
Old Jun 8, 2009 | 02:22 AM
w0ady's Avatar
fgc moderator
if its on your record as good faith they have to fix it but they might be stringing you along. get someone to give you an accurate estimate of whats wrong. ive always heard good things about christian @ lokey so maybe he can help you out.
Old Jun 8, 2009 | 10:26 AM
black_sedan's Avatar
is there enough fluid in the tranny?
Old Jun 8, 2009 | 03:23 PM
Sen's Avatar
Sen
If you know how to recreate it, why don't you show them yourself?
Old Jun 8, 2009 | 10:41 PM
ltorres781's Avatar
it mainly happens when im stuck in rush hour traffic or after a long drive.. i took it to them so they could drive it.. but they couldnt recreate it after driving it... its becomin a pain because at times im stopped at a light and cant get it into first gear after either jigglin it a few times.. or forcing it in... my drivetrain is still under warranty.. so thatz y i been back numerous times.. i guess ill call lokey and try my luck there
Old Jun 12, 2009 | 09:56 PM
sameo2's Avatar
what kind clutch they install??and ask them if they use nissan fluid on the tranny...this usually hapend when the car has diferent fluid in the tranny....or just bring the car to lokey ill check this out for you..
Old Jun 14, 2009 | 11:43 PM
ltorres781's Avatar
ok when should i bring it in so u can look at it?
Old Jun 15, 2009 | 09:09 PM
sameo2's Avatar
^ anytime just call and make the appointment!!
Old Jun 16, 2009 | 10:45 AM
ltorres781's Avatar
is christian a service advisor... and should i ask for him when i make an appointment with him
Old Jun 16, 2009 | 10:50 AM
Kidcane's Avatar
^^He is a tech and works on most the FGC cars. Your advisor would probably be Christina..if you are lucky.
iamericgee's Avatar
talk to christina and tell her you want christian to work on your car !
Old Jun 16, 2009 | 10:58 AM
_jb's Avatar
_jb
Photographer
Yep...
Christene - 727.374.2311 Direct.
-jb
Old Jun 16, 2009 | 11:04 AM
ltorres781's Avatar
thanx guys i really appreciate all the help
Old Jun 16, 2009 | 02:29 PM
Mortaki's Avatar
Last time I had an issue I went to Lokey and I worked with both of them. They were both great. Christina told me about the $109 feed to diagnos what my issue was and that would be applied to any repairs that were not covered by my standing warrenty. I had an issue with the TPS where at a redlight my car would just die. I would hit the gas and the car would move like I had just left off the brakes. it was covered and they even waved the diagnoses fee. Christian even talked with me about doing turbos on mine soon. great peeps.
