Invalid_User
close
- Join DateSep 2007
- LocationTampa,Florida
iTrader Positive Feedback100
iTrader Feedback Score(23)
Liked:217 Times in 146 Posts
^yea i meant to say you cant use the toe arm unlesss you have a true coilover setup
^+1
JBALLA, if I remember correctly you are on stock 19's right? In that case it is most likely your toe thats all jacked up.
If you are at -2 degress camber and you like the camber you are fine and you really don't need camber arms just toe bolts. But if you want to get back into spec with camber get the camber arms as well.
