Please help me local guys!!!
Old Oct 29, 2009 | 08:53 AM
JBALLA's Avatar
Ok so here is the problem my tires keep feather/chopped!! I have owned the car for a year now and this is my second set of tires. I originally had sprint spings with a 2" drop all the way around with stock shocks. I thought it was my shocks due to the aggressive so I bough Tokico Dspecs. My camber has always been hella off but would a camber kit help stop the chopping/feathering???
Old Oct 29, 2009 | 08:57 AM
iamericgee's Avatar
get a camber kit u should be fine
Old Oct 29, 2009 | 09:05 AM
JBALLA's Avatar
did something like this happen to you
Old Oct 29, 2009 | 09:13 AM
iamericgee's Avatar
it happens to everyone who lowers there car . u have to get a camber kit start with a spc toe bolt
Old Oct 29, 2009 | 09:56 AM
ishiftinheels's Avatar
Teh Redhead Moderator
A 2" drop with no camber kit or toe bolts??? Definitely get some, asap!
I'm using SPC toe bolts and my camber arms are from Fidanza.
Old Oct 29, 2009 | 10:19 AM
JBALLA's Avatar
how much positive can you go with the fidanza camber arms I am -2 Degrees all the way around
Old Oct 29, 2009 | 10:42 AM
I have no idea... I don't think they are actually made by Fidanza, that's just who I got them through. I don't know what brand they are. Here's a pic. The camber arm is the one on the left. On the right is the toe arm.
Old Oct 29, 2009 | 12:22 PM
Sen's Avatar
Sen
Feathered tread? If the tread is wearing sideways (kinda sickle shape) then it's your toe. That's even worse for wearing out tires.
Camber will result in wearing out on just the inside of the tire (which is bad, too). The way suspension works usually, if the camber is out, your toe goes out too. If you can fix your camber, then it usually fixes your toe. And sounds like you need to fix it bro!
Old Oct 29, 2009 | 12:39 PM
escobar929's Avatar
to me it sounds like its your toe, i know plenty of people running -2 camber and they not have the a feathering problem
just dont expect your tires to last more than 10k miles
Old Oct 29, 2009 | 01:03 PM
w0ady's Avatar
fgc moderator
+1 for sen and jose. TOE is way more important than camber. either way, get some front and rear camber arms and rear toe bolts.
Old Oct 29, 2009 | 01:18 PM
Invalid_User's Avatar
yes get both arms and toe bolts.
Old Oct 29, 2009 | 01:19 PM
If you just want toe bolts here
http://www.importpartspro.com/spcretoadbok2.html
Old Oct 29, 2009 | 01:20 PM
Where did you get these from??
I dont think you can use the Toe arm unless you have a True coilover setup .
Old Oct 29, 2009 | 01:52 PM
^ I didn't use the toe arm.... It was just in the picture. Got them both through Fidanza....
Old Oct 30, 2009 | 10:45 PM
Sen's Avatar
Sen
Oh that's interesting. Last I remembered, the "toe arm" in the rear is the actual spring bucket. I guess that's what he meant coilover setup.
