scratching/ WHIRR type noise when lightly braking..
Old Feb 7, 2010 | 09:41 PM
Nightm4re's Avatar
Car doesnt SEEM to be leaking anything... i was under it for a while yesterday and today.
as for bushings, i have no idea
Old Feb 7, 2010 | 10:10 PM
VDC_OFF's Avatar
Well if it's coming from the front, it's not cv joints. I have a ticking noise coming from the front when i turn to the right. I was thinking a bearing also but I haven't been able to check it out. A bad bearing wouldn't explain the groove on your rotor. Keep us posted.
Old Feb 8, 2010 | 09:43 PM
Nightm4re's Avatar
FIXED!
It turns out... that ......
a bolt that holds the caliper on... was missing on the passenger side of my car. I put a temporary bolt in there and went to the auto parts store and ordered it... for $20. The clinging i heard going over bumps was the caliper moving up and down and hitting the rotor... the WHIRR noise was the caliper moving down and resting on the rotating rotor. (this was the top bolt for the caliper, not the bottom)
Old Feb 9, 2010 | 08:00 AM
Gilley's Avatar
Good thing you found it before something bad happened. You should be mad at whomever did your brakes. They need to tighten the caliper bolts a lot.
Old Feb 9, 2010 | 09:42 AM
Nightm4re's Avatar
I did my own brakes like... 5 months ago. Weird that the bolt fell out after like 5 months. I made sure that they are all super tight now though.
Old Feb 10, 2010 | 07:55 AM
Gilley's Avatar
Doh!!
Old Feb 10, 2010 | 11:51 AM
Sen's Avatar
Sen
Whoa that sucks man. One of the sliding pins for the caliper or one of the torque member (bracket) bolts? I woulda thought that your caliper would be flappin all over the place if that was the case.
Old Feb 10, 2010 | 05:13 PM
Nightm4re's Avatar
The one that holds the actual caliper to the bracket.
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
Joshua615
Aug 31, 2015 12:29 AM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
atk08
Jul 30, 2015 03:12 PM
papo020
Jul 17, 2015 10:30 PM
