Unusual Clicking?
Old May 24, 2010 | 09:01 PM
CG4DR's Avatar
Unusual Clicking?
https://g35driver.com/forums/drivetr...um-change.html
Doesn't seem like many people read the tech area
Old May 24, 2010 | 09:08 PM
intense660's Avatar
its probably compression rods
Old May 24, 2010 | 09:13 PM
blAk mAx's Avatar
there is nothing unusual about the clicks..common problem.. i think u need to grease the bearings or something ? if your under 70k have the dealer fix it
Old May 24, 2010 | 09:27 PM
blAk mAx's Avatar
search the for clicking
found this in another thread:
Go download the TSB - one link is here: www.infinitihelp.com you just have to register to be able to download the pdf of the TSB.
It's lack of lubrication on the splines of the axle, they use a moly-based grease, take it apart, put it together. IIRC the only parts were a bolt on each side the FSM cautions you not to re-use.
ITB05-002b
2003–2005 G35 SEDAN AND COUPE; CLICKING NOISE FROM REAR AXLES
A "clicking" noise is coming from the left and/or right rear axle (driveshaft) when accelerating from a stop.
Old May 24, 2010 | 11:07 PM
CG4DR's Avatar
will the dealer fix it with me being slammed? lol
Old May 25, 2010 | 08:53 AM
Kidcane's Avatar
Prolly not man. They could easily say it was caused by lowering. Lokey would be your best shot if anyone will do it.
Old May 25, 2010 | 11:25 AM
ishiftinheels's Avatar
Teh Redhead Moderator
I was gonna say come see us but you're closer to Lokey or Tampa than Orlando... good luck!
Old May 25, 2010 | 12:01 PM
143TRUST's Avatar
Mine clicks when going from reverse to drive Lokey said it was my eibach springs and there was nothing they could do.
Old May 25, 2010 | 01:55 PM
CG4DR's Avatar
Tampa said no. Blue I might head out there one day if you want to make me an appointment and I can come in and wait. Just pm me for my info if you need it
Old May 25, 2010 | 02:01 PM
Tampa said no... why??
I will make the appt for you, just let me know your schedule.
Old May 25, 2010 | 02:22 PM
CG4DR's Avatar
Coilovers. Next week Tuesday or Thursday.
Old May 25, 2010 | 02:27 PM
Oh. I sent you a PM already.
Coilovers aren't a problem here.
Old May 25, 2010 | 04:54 PM
Invalid_User's Avatar
weird i had mine done with my coils
But I raised it up to oem height before i went there
Old May 25, 2010 | 05:02 PM
CG4DR's Avatar
they said that they would know if its been modified, i thought to myself i sure as hell hope so.
Old May 25, 2010 | 05:07 PM
Go to lokey they will help you out.
