January 2011 discussion thread !!!
Old Jan 11, 2011 | 06:52 PM
  #376
NFSP G35's Avatar
? = 2B || !2B
^Or sandwich the rubber thing around your oil filler neck in the plenum
Old Jan 11, 2011 | 06:56 PM
  #377
SN00P's Avatar
CLUB MODERATOR
thats just an extra little gasket i did LOL
Old Jan 11, 2011 | 06:58 PM
  #378
NFSP G35's Avatar
? = 2B || !2B
^Oh ok.... like a partial 1/16th spacer??
Old Jan 11, 2011 | 06:59 PM
  #379
My Key's Avatar
Originally Posted by g35snoop
and as far as the installation, if you can change a tire and put a intake filter on you car then you can easily install a plenum spacer without any problems but make sure you don't over tighten any of the screws and should follow the torque specs
yeah. I'm a little worried about over tightening. What happens? Do the screws break off?
If I can change the windshield wipers by myself, does that mean I have the necessary skills to do this plenum install?
Old Jan 11, 2011 | 07:04 PM
  #380
SN00P's Avatar
CLUB MODERATOR
i always wondered where i got a little HP at higher RPM sss HMM i know the reason now LMAO
  #381
NFSP G35's Avatar
? = 2B || !2B
^If you over-tighten, you can strip the aluminum or break the bolt (either of which really suck, but both can be fixed)
It's really not hard to do though. Just use a alan drive screwdriver, and tighten it down good enough, and it won't strip. You'd have to really torque on it with a screwdriver to strip it.
Also, locktite on the threads is recommended.
Old Jan 11, 2011 | 07:06 PM
  #382
SN00P's Avatar
CLUB MODERATOR
you will strip out the threadings but the best thing you can use is a torque wrench in inches not pounds lol ill find out the thread where it gives you all the specs and the way you go about tightening each screw/screws in order ..
edit here is the site for everyone who didn't know the specs of a plenum <--- very very helpful
http://www.myg35mods.com/tutorials/spacer/index.html
Old Jan 11, 2011 | 07:12 PM
  #383
My Key's Avatar
all good, man. I don't need it NOW. haha
Old Jan 11, 2011 | 07:17 PM
  #384
SN00P's Avatar
CLUB MODERATOR
lol well you can always find this thread for when you decide to install it in case you forget :-) but ashley can use it lol but im sure he already knew that lol
Old Jan 11, 2011 | 07:37 PM
  #385
CG4DR's Avatar
That's the spacer I have. I love it
Old Jan 11, 2011 | 08:34 PM
  #386
blAk mAx's Avatar
Old Jan 11, 2011 | 08:36 PM
  #387
iamericgee's Avatar
We’re going to have a network wide outage TODAY between 10:00 – 11:30pm PST. It is possible the network may go down for up to 30 minutes during that time. Thanks.
https://g35driver.com/forums/announcement.php?f=&a=90
Old Jan 11, 2011 | 08:46 PM
  #388
blAk mAx's Avatar
its the y2k11 bug
Old Jan 11, 2011 | 08:48 PM
  #389
NFSP G35's Avatar
? = 2B || !2B
What is that in normal-people time?
Old Jan 11, 2011 | 09:14 PM
  #390
ilovez33's Avatar
Bout 1 Oclock for us if im correct
