FGC's Hot August Discussions
Old Aug 5, 2011 | 10:24 AM
  #376
SN00P's Avatar
CLUB MODERATOR
Originally Posted by Evil Wayzz
Vossen 19x8.5 and 19x9.5 vvs 075
NEED SPACER!
someone give me a 10mm in front and 15 mm in rear!
and some springs.
i told you 20-25mm spacers dude 10mm wont do anything on your 8.5 lol you still will be hella sunkkkkkkkk
Old Aug 5, 2011 | 10:27 AM
  #377
gannicus's Avatar
Yeah I know. I am going to sell my bumper
Old Aug 5, 2011 | 10:42 AM
  #378
Black07Gcoupe's Avatar
Hey everyone I am looking to get an Air Compressor for various reasons but the main one would be to easily remove my lug nuts and switch wheels as fast as possible; any one have an idea of how much PSI it would take to remove the lugs? Or is there a better way besides the standard tools Infiniti gives you?? Thanks!
Old Aug 5, 2011 | 10:53 AM
  #379
SN00P's Avatar
CLUB MODERATOR
^^^ i dont use a gun AT ALL for my lug nuts period !!! im sure alot of the other guys dont either .
when putting the wheels on i use my tourqe wrench and have it set at 80 pounds so i know they wont break and they will come off easy
i can take a set of wheels of on my car by the time you keep the tank full and move it around everywhere...
manual labor never hurts anyone.. better to be safe then snapping studs ..
but i do have a air tank for bolts under the car when im working and thats about all i use it for and i have my tank set at 180psi and i very nice impact gun ...
i used it the other day on my buddies nissan stock wheels and lug nuts and it worked just fine
Old Aug 5, 2011 | 10:59 AM
  #380
Damn didnt realize I could break lug nuts. Sounds like a torque wrench it is! Thanks Snoop!!
Old Aug 5, 2011 | 11:05 AM
  #381
SN00P's Avatar
CLUB MODERATOR
and break your studs man !! pain in the *** !!! do everything correctly and it will save you trouble later on trust me i have been there and many guys have had same problem ... using a gun can over tighten the lug nuts ASK ERIC
Old Aug 5, 2011 | 11:07 AM
  #382
ilovez33's Avatar
What Sn00p said, Saves you from stripping a stud, Plus impact guns can damage the paint around where the lug nut is. I specfically told a shop not to use an impact gun on my TE's and the dumbass still did it and they ended up chipping part of the paint....
Old Aug 5, 2011 | 11:08 AM
  #383
ilovez33's Avatar
And that was an AWESOME find on the $100 Nismo Ellison.....Tell danny I said whats up.
Old Aug 5, 2011 | 11:11 AM
  #384
gannicus's Avatar
i will man. i trying to sell my oem sport bumper for 200 bucks.
Old Aug 5, 2011 | 11:12 AM
  #385
Yeah exactly it will be more trouble later! The gun is defiantly out, I couldnt risk hurting my girl like that. Thanks for the advice. How about when I go to jack up the car, and remove the wheels i was gonna go get 4 jack stands and a nice 3 ton floor jack...any suggestions for some technique better than this?
Old Aug 5, 2011 | 11:19 AM
  #386
HavokGT's Avatar
id make the ******* pay for it.
  #387
Damn, that sucks. Yeah sounds like the impact gun would be maddd over kill.
Old Aug 5, 2011 | 11:22 AM
  #388
CG4DR's Avatar
invest in a battery powered 3/8'' rachet. when you break loose the lug nuts you can use it to take them off instead of by hand
make sure you get short jack stands.
  #389
Kidcane's Avatar
You guys worry too much. Gun can be used to remove the lugs but NEVER to put them on. Use a torque wrench for that. As long as the gun has a socket that fits inside the area for the lug without scraping you are fine. Then wrap some electrical tape around the socket for extra protection.
Old Aug 5, 2011 | 11:23 AM
  #390
SN00P's Avatar
CLUB MODERATOR
^^^ i normally never jack up all 4 corners i do one at a time but thats me ..
but i do have jack stands for when i work under the car tho which is good to have ...
4 jacks and a low pro jack will do the trick buddy
