My engine is about to die !??
Old Oct 20, 2011 | 10:45 AM
iamericgee's Avatar
Unhappy My engine is about to die !??
For sometime now my low oil light has been coming on every so often goes away when i give it gas but pops up when im at idle so last night my buddy says that it means that my engine life is about due to start looking for another motor he gave me the run down on how it has something to do with the compression rods slowly giving away ? so is this true ? what should i do ?
Old Oct 20, 2011 | 11:38 AM
warzywko's Avatar
I had a similar problem on a build motor, but in addition I had lots of whine coming from the oil pymp. I do have a oil pressure gauge and it was showing good oil pressure. Few days later oil pressure started jumping up and down and engine developed a knocking sound and lots of vibrations..... spun 2 main bearings .
Check your oil pressure . But most likely its your bearings ....
Old Oct 20, 2011 | 12:08 PM
WILLIE BEANS's Avatar
Damn that sucks .
Im getting a clicking noise coming from engine also . But just a lil here n there whene i drive more spiritedly .
Old Oct 20, 2011 | 12:48 PM
ilovez33's Avatar
I started getting a chatter from my transmission a week ago. Only when I come to a stop and then start rolling again, I get a slight chatter from the transmission.
Old Oct 20, 2011 | 01:01 PM
iamericgee's Avatar
yeah he told me the bearings is going bad most likely he said to use thicker oil that it will help but to start looking for another motor
Old Oct 20, 2011 | 02:32 PM
Ryan@Forged's Avatar
Is the motor consuming any oil? Keep an eye on your oil level and oil pressure. It's possible it may be on it's way out, but not guaranteed. It also may be a good idea to have a compression/leakdown test done to check the integrity of the motor.
Old Oct 20, 2011 | 02:46 PM
Sparda1123's Avatar
Its most likely the main bearings or rod bearings a friend of mine has 186k on his and his bearing just broke apart into a bunch of pieces and hes in the process of rebuilding it. But his was making a slight knock at first then it got worst until it sounds like someone took a box of screw threw it in his motor and closed it.
Old Oct 20, 2011 | 03:23 PM
iamericgee's Avatar
ryan i havent tried any compression tests yet but i sure will this weekend
Old Oct 20, 2011 | 03:29 PM
g35man04's Avatar
CLUB MODERATOR
if you need another motor let me know! I will have mine available. Its got 92k on it..im working on moving into an LS1 on my G.
Old Oct 20, 2011 | 05:00 PM
iamericgee's Avatar
How much u want ?? Pm me a price dude
Old Oct 20, 2011 | 05:31 PM
w0ady's Avatar
fgc moderator
how many miles are on your motor?
Old Oct 20, 2011 | 06:24 PM
iamericgee's Avatar
some where around 94000 miles
Old Oct 20, 2011 | 07:44 PM
Gettinby's Avatar
You should just buy my car an call it a day
Old Oct 20, 2011 | 08:08 PM
98intrigue's Avatar
I'll have a VQ37VHR up for sale soon
Old Oct 20, 2011 | 08:52 PM
ilovez33's Avatar
Shipping that motor from texas might be a bitch though. Maybe Turbo Toys might have one local?
