Spark plugs
Old May 13, 2012 | 03:48 PM
Aero09's Avatar
Spark plugs
Which spark plug do you guys recommend for my coupe?
Old May 13, 2012 | 04:52 PM
seymore4's Avatar
m56
From my experience and seeing many, many cars on the dyno this is the best plug:
Amazon Amazon
Its one step colder than stock, if you want the stock heat range grab the LFR5
Old May 13, 2012 | 08:43 PM
ilovez33's Avatar
What he said^ Noticed a big difference when I changed my plugs and used those.
Old May 13, 2012 | 10:02 PM
blAk mAx's Avatar
i have a used set. less than 10k miles
Old May 13, 2012 | 10:50 PM
Aero09's Avatar
alright thanks i'm going to pick some tomorrow i really need to change my spark plugs out
Old May 14, 2012 | 12:35 AM
seymore4's Avatar
m56
Check for oil in the tubes when you do
Old May 14, 2012 | 09:47 PM
NFSP G35's Avatar
? = 2B || !2B
^Yep. Especially cylinders 5 and 6
Also: https://g35driver.com/forums/engine-...ark-plugs.html
Old May 14, 2012 | 10:25 PM
Aero09's Avatar
I went with the ngk iridium, bought today but my battery also died at the store had to buy a new battery. Changed out my spark plugs and I have oil in the tubes, how do I solve this issue now?
Old May 14, 2012 | 10:38 PM
seymore4's Avatar
m56
buy new valve covers. bye bye $$
Old May 15, 2012 | 12:58 AM
NFSP G35's Avatar
? = 2B || !2B
^Not necessarily, somebody makes replacement seals. They're a vendor on here, I just can't remember who.
Old May 15, 2012 | 01:01 AM
seymore4's Avatar
m56
I believe you have to buy the whole valve cover from them and send in yours as a core... don't remember the cost but I'd rather just get new oem.. The newfangled replacements haven't been around that long who knows how long they're going to last?
Old May 15, 2012 | 01:14 AM
NFSP G35's Avatar
? = 2B || !2B
^Not the one I remember.
Old May 15, 2012 | 11:52 AM
G35 Drummer's Avatar
How did you fix your "oil in #6"?
do you have upper and lower plemun installed?
Old May 15, 2012 | 02:16 PM
ilovez33's Avatar
Actually. The company is RD Factory Here on Driver. And they do sell the gaskets seperatly. They'll send you the diagram on where to drill out if you choose the route.
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
