Some pics of the build!
Old Jun 9, 2005 | 09:49 AM
  #31
SFLG35's Avatar
FGC President
dont forget your 1000 mile breakin first though.
Old Jun 9, 2005 | 10:11 AM
  #32
djniknala's Avatar
I didn't touch the motor yet so I am going to "rape it" right away.
Old Jun 9, 2005 | 11:53 PM
  #33
djniknala's Avatar
A couple of the "after" pics. It feels pretty fast even at the wastegated 5.5psi. Tommorrow I'll turn up the boost! Woohoo. Thank good for that TS flash and J&S. That gives me great piece of mind.
Old Jun 10, 2005 | 12:02 AM
  #34
SFLG35's Avatar
FGC President
why are they always so small???????????
Old Jun 10, 2005 | 12:14 AM
  #35
Gman2004's Avatar
Very nice. How many psi are going to boost to? Are you using the TS flash as a base tune and then fine tuning with emange for higher boost?
Old Jun 10, 2005 | 12:25 AM
  #36
djniknala's Avatar
Daily 8psi. Hi boost of 10psi. I'm going to build another motor so now worries on popping this one. I'm using the TS as the base and then tuning the ignition with the J&S and injectors with the emanage.
Old Jun 10, 2005 | 12:31 AM
  #37
Gman2004's Avatar
Sounds good. I have a very similar set up to you. I am going to be boosting 10psi on low and 12psi on high. I am sending my ECU to get flashed but not the greddy flash. The ECU has 3 timming maps limp, normal, and agressive. I am going to have them copy the normal into the agressive map and then tune with the emanage. This way the ECU doesn't just decided to switch to the agressive map while in boost and KABOOM. I am also going to run water injection just for safety. Good luck and enjoy.
Old Jun 10, 2005 | 12:52 AM
  #38
djniknala's Avatar
Sounds good. I'd like to compare notes with you. You going to the meet? I wonder how many FI peeps will be there.
Old Jun 10, 2005 | 01:05 AM
  #39
Gman2004's Avatar
Well I probably be there be unfortunately my car won't. I won't get my motor back from SGP Racing for about 2 weeks. Here are some pics. I am waiting on my fuel pressure gauge.
Attached Thumbnails Some pics of the build!-engine-bay.jpg   Some pics of the build!-boost-timer.jpg   Some pics of the build!-gauges.jpg
Old Jun 10, 2005 | 01:16 AM
  #40
djniknala's Avatar
That's cool. Before today I hadn't driven my G35 for 2 weeks. I bought a QX4 VQ35 motor so I won't have to go without the car for an extended period of time. I'm gonna pm you my number so we definitely get to compare notes this weekend.
Old Jun 10, 2005 | 01:21 AM
  #41
Gman2004's Avatar
I've been without my car since 03/25...ouch! Got your pm....see ya at the meet.
Old Aug 7, 2005 | 06:38 PM
  #42
djniknala's Avatar
A little update:
I had my car for a total of 2 days since May 8. Got the car totally done with the forged motor for the break in. Stayed with the 440 injectors for now for convenience and I don't want to push it that hard. Boosting to 11-12psi. That's the highest I could go fuel pressure and injector duty cycle wise without going over 11.8:1 A/F. I found a little program that lets you put my wideband output into the emanage and log it along with everything else. I like road tuning because as long as the numbers are right the power will be there.
Big thanks goes out to: Larry at Innovations(putting up with me just about every other day after work at his shop), Brian at Technosquare for coming in while he was sick to reflash the ecu due to some weird checksum errors, Steve(G356gear) for selling me his totally built motor that was built by a great shop and selling it to me for a great price, Eric Summers at Titan Motorsports for tracking down all the parts that weren't sent(who needs two left side downpipes, I didn't) and for the discount(no one tell Nero) and all the guys in the FI forums at my350z.com and g35driver.com. Last but not least Ross for painting my bumper and being my best friend. This thing is fun even at this power level(I figure 475lb/ft and 430whp because I'm letting the boost spike a little at first) and that means alot coming from a guy that has two very fast bikes.
Full mod list
Arias 9.0:1 pistons, Pauter H beam rods, ARP head, main
and rod bolts, JWT S1 cams, port and polish heads and intake runners,
Crawford cast plenum.
Greddy turbo kit with FMIC, Type RS blowoff valve, Profec B spec 2
boost controller
Walbro fuel pump and Altered Atmosphere full return fuel system with Aeromotive FPR
Ceramic coated manifolds, turbo hot sides, downpipes, wastegate pipes
and test pipes.
Borla true dual exhaust
Greddy Gracer front bumper and blacked out rear bumper lower valence
Kazera KZ-A's 18x8.5 front with Yokohama AVS ES100 245/40/18, 18x9.5
rear with BFG g-force T/A drag radials 265/40/18
PLX m300 wideband, greddy electronic egt and boost, J&S Safeguard with
remote knock and a/f gauge.
Hotchkis 3 way adjustable sway bars, Kinetix rear traction arms and
camber arms, Innovations Performance custom line lock kit, EBC greenstuff pads and stainless steel brake lines to
compliment the factory Brembos.
Hifonics Brutus 1500 running 900watts RMS to one JL 10w6v2 in a custom
molded fiberglass box and a Hifonics Zeus 6400 running two sets of
Focal utopia mids and highs. Optima yellow top
Oh, and yes I did scrape my bumper good coming out of the mall parking lot at the meet. See everyone soon(hopefully the dyno day).
Alan
Old Aug 7, 2005 | 07:29 PM
  #43
Audible Mayhem's Avatar
nice... hey i need ross to paint some stuff for me soon. i forgot thats what he does, hehehe
Old Aug 7, 2005 | 09:14 PM
  #44
PearlWhite03's Avatar
Nice. I'm very impressed. I have been saving up for my build as well.
Old Aug 7, 2005 | 11:09 PM
  #45
TINMAN's Avatar
very nice.very very nice
