KPTechnologies Shift Lights
Old Dec 18, 2005 | 07:39 PM
  #226
Meatshackle's Avatar
Deep Sea Moderator
I think mine is an 03.5, got it brand new in May '03. I used the middle brown wire and had no probs.
Old Dec 18, 2005 | 07:46 PM
  #227
SFLG35's Avatar
FGC President
take some pics of you ecu and post them. that will help me try and point you in the right direction.
Old Dec 18, 2005 | 09:34 PM
  #228
nsanbyker's Avatar
pics of the ecu or of the ecu harness? i'm going to dive back in tomorrow. wish me luck and patience. thanks for the help guys. later
Old Dec 18, 2005 | 11:48 PM
  #229
SFLG35's Avatar
FGC President
the harness
Old Dec 19, 2005 | 07:42 PM
  #230
nsanbyker's Avatar
I can't upload the pics because they are too big. Can I send them to you (SFL
G35) via e-mail or can someone tell me how to reformat the pics to make them uploadable.
Old Dec 19, 2005 | 11:57 PM
  #231
SFLG35's Avatar
FGC President
sure send them to me at daniel.bazley@kptechnologies.com or find me on AIM.
Old Dec 21, 2005 | 02:13 PM
  #232
shooter's Avatar
It's not the critic......
hey dan........still waiting on the auto door locking mod.........
Old Dec 21, 2005 | 03:10 PM
  #233
SFLG35's Avatar
FGC President
hmm
i sent it two day.
hopefully it should be there today.
let me know if its not and ill see what i can do
Old Dec 21, 2005 | 03:55 PM
  #234
dabomb's Avatar
FGC Central Florida BOD
Hey guys,
Dan installed my sunroof mod last night. I think its about the 3rd or 4th he has done. He is getting quick and I highly recommend him if your unsure about doing it yourself. And FGC discounts apply!!!
Thanks again Dan!!!
Old Dec 21, 2005 | 05:58 PM
  #235
shooter's Avatar
cool........just got the package dan
now to the install!
Old Dec 21, 2005 | 08:53 PM
  #236
SFLG35's Avatar
FGC President
alright here are some more pin colors for you guys to check to make sure you have the right wire.
pin 10 - white / green
pin 11 - red / white
pin 12 -
pin 13 - brown - crank sensor wire
pin 14 - yellow - cam shaft
Old Dec 22, 2005 | 01:49 AM
  #237
SFLG35's Avatar
FGC President
more from kevin
Pin 8 – NC
Pin 9 – NC
Pin 10 – White/Green
Pin 11 – Red/White
Pin 12 – Blue/White
Pin 13 – Brown (Crank angle)
Pin 14 – Yellow
Pin 6 is the start of a row (pins 1-5 are a relay)
Pin 32 (above pin 13) – Pink
All wires match up to what the service manual says they should be.
Hope this helps
guys its not that hard
tom those pics you sent are right on
that wire you have should be the coorect one.
Old Dec 22, 2005 | 04:01 AM
  #238
Deep Sea Moderator
I'm having a serious problem with my shift light. When I first installed it, everything was great. Now I can't see it at all.
Old Dec 22, 2005 | 07:03 AM
  #239
neffster's Avatar
http://www.kptechnologies.com/forums
Go here (it's a secret world) and post your problems. Be prepared for a rapid fire slew of posts and it might help if you keep your screen name (he he he).
Did it fall back inside of your gauge pod maybe? Did the Power wire come undone?
Old Dec 22, 2005 | 09:57 AM
  #240
SFLG35's Avatar
FGC President
im lost
