Running 245/35-19" and 275/35-19"?
Old Jan 12, 2006 | 02:49 PM
FLFIRE's Avatar
Anyone running 245/35 front and 275/35 rear on OEM 19"? If so, what tire make do you have and what are your thoughts on the setup?
Thanks
Old Jan 12, 2006 | 02:50 PM
escobar929's Avatar
that might be a lil too buldgy on a stock rim
Old Jan 12, 2006 | 03:10 PM
_jb's Avatar
_jb
Photographer
Here's a whole thread on that subject.
https://g35driver.com/forums/wheels-tires/73638-275-s-oem-19-s.html
Executive Simmary: Several people have done it with success, but there are naysayers...
Old Jan 12, 2006 | 03:30 PM
FLFIRE's Avatar
Thanks. I did go to the tirerack.com site and they do specify this as an upsize option. I'm hoping there is someone in Fl who has done this so I can get some firsthand feedback and take a look at their setup.
Old Jan 12, 2006 | 08:07 PM
Finiti35's Avatar
FGC South Florida BOD
I'm running 245/35 and 275/30 Falkens on OEM 19". Gotta tell you Tony, BIG difference compared to my stock setup. I had no 1st/2nd on stock Contis and my car just spins and spins and spins with more than half tread left, but it's no secret that Contis are garbage. The added grip helps a lot at least with the kind of power I have. Haven't pushed the car into any kind of 'twisties' around here yet so I cannot comment on the handling. But if anything wider tires simply look better on the car.
However, my rears are 9.5".. on a 8.5" wheel I'd go with 255 or 265. Get rid of some of that understeer.
Old Jan 13, 2006 | 08:32 AM
r10apple's Avatar
The recommended thread is quite good. My dad was in the tire business for over 25 years: You can indeed run this set-up, but it will depend on the make and design of the tire you select as well as the proper inflation. You can easily get uneven wear with this, but a good shop CAN help you out and advise you in person. I would not order this set-up over the internet at all--face to face with prior fittament is a must. You may end up trying various brands of tire to get the best, most even contact patch...
Good luck!
Old Jan 13, 2006 | 02:00 PM
escobar929's Avatar
what u havent? u have prez circle right there, not only is it the best place for pics, but its the only place were u can bust 60mph+ turns
Old Jan 13, 2006 | 02:09 PM
Finiti35's Avatar
I would, but I don't have my car. It's at the dealer until next week. Stupid BMWs, they break down so much blah blah.
Thebaws11
Jul 2, 2021 11:36 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
