PCI Express Video Card
Old Feb 13, 2006 | 08:48 AM
SFLG35's Avatar
FGC President
anyone got one
mine just **** a brick and doesnt work anymore.
does anyone have one i could borrow for al ittle while?
im sending mine back into evga to get it fixed
thanks
Old Feb 13, 2006 | 11:51 AM
escobar929's Avatar
that sux, maybe its time to upgrade
Old Feb 13, 2006 | 12:48 PM
SFLG35's Avatar
FGC President
i just did upgrade it
its not even a year old yet
Old Feb 13, 2006 | 02:22 PM
_jb's Avatar
_jb
Photographer
You're thinking of PCI.
PCI-Express is newer than AGP... so not many of us have spares yet.
Old Feb 13, 2006 | 02:25 PM
Real_G's Avatar
An Army of One...
I have yet to make the jump to PCI-E , My 8X AGP is still kicking (plays BF2).. maybe I'll have another yr or two till I upgrade..
Old Feb 13, 2006 | 04:01 PM
dabomb's Avatar
FGC Central Florida BOD
well he said its less than a year old...i think he is talking about PCI-E
Old Feb 13, 2006 | 04:03 PM
SFLG35's Avatar
FGC President
so no one has any spares
or does anyone have it to where i could maybe stick mine in it to see if its my video card
heres what happens
i was formating my new hard drive and installing windows.
it was doin fine and then the screen just goes black. the lights on the monitor stay on so its not like the pc has shut down. the computer still runs, but there is no screen.
sometimes the screen will wake up out of stand by but it will just be black.
im pretty sure that its the card but i dont know for sure
Old Feb 13, 2006 | 04:04 PM
SFLG35's Avatar
FGC President
yes its less than a year old
its a evga geforce 6600 pci express x16 card.
Old Feb 13, 2006 | 05:08 PM
_jb's Avatar
_jb
Photographer
Originally Posted by SFLG35
heres what happens
Does your motherboard have video? If it does, change the BIOS to use the on-board video, move your VGA connector to the motherboard, and see if that works.
Do you have any of the run-time versions of Windows or Linux? Something like BartPE or Knoppix? If so, try booting from one of them and see if the graphics card works. Or, boot up from a bootable DOS diskette if you still have one.
Make sure it's not going into hibernate mode. Press the Off switch and hold it in for ten seconds. That sounds stupid, but it turns it completely off. Then try turning it back on and see if the video starts.
Old Feb 13, 2006 | 05:51 PM
SFLG35's Avatar
FGC President
motherboard does not have on-board video.
no i dont have a run time version
no i dont have a bootable diskette, just use the cd drive.
its not goin into hibernate mode, the computer is still running just the screen goes blank. and when i hold the button the comp turns off completely but when i turn the screen on it does the same thing over again
do you think my new serial ata drive could be causing the problem??
this it the first time i have ever used a serial ata drive. i also noticed that it seemed to get significantly hotter than my old ide drives
Old Feb 13, 2006 | 06:10 PM
_jb's Avatar
_jb
Photographer
Serial ATA drives do have some odd characteristics, but I don't think they would cause the problem you're having. Some motherboards need an additional card to connect Serial ATA drives. Did your motherboard have Serial ATA connectors on it?
After having said that, if you still have your old IDE drive laying around, I'd put it back in and see if the video works with it.
Most times... when things go wrong during an installation... I find the problem is in the new installation... the odds of a video card going bad right when you install a new hard drive seem remote to me. Unfortunately, it does happen though...
Old Feb 13, 2006 | 06:11 PM
_jb's Avatar
_jb
Photographer
ps: check for bent pins in your monitor's VGA cable connector.
Old Feb 13, 2006 | 06:28 PM
Nuggle's Avatar
if you plan on upgrading and sticking wiht amd wait till socket M2 comes out it supposedly gonna be around just as long as the old socketA
on the whole PCI vs. PCI-E this kid still managed to mix up pci and destroyed a brand new 7800GTX
Old Feb 13, 2006 | 07:01 PM
Polishthrust's Avatar
What a waste, you NEVER cut connectors like that.
As for your problem, you can go back to the last set up that actually worked and start from there, narrowing down to 1 thing.
I think something similar happened to me, and it turned out it was the power supply burned out. The pc still powered on, but there was not enought power to really run anything so screen stayed black. Make sure you PS has enough power to run everything without running 100% all the time, PCIE take more juice.
Other than that, always check ALL nonnections. All cables, and even all the cards in the pc, even RAM.
Old Feb 13, 2006 | 10:40 PM
SFLG35's Avatar
FGC President
no my motherboard has 4 serial ata ports on it
the mother board i have is a abit fatal1ty an8
the processor is a amd 3800+
the power supply is a antec true control 550w
the video card is a evga e-geforce 6600
all are less than a year old and were bought at the same time.
