Brembo Pad Installation
Old Feb 21, 2006 | 10:50 PM
JuicedAthletics's Avatar
Hey guys..
Just wanted to know if you knew anywhere I could get a Brembo brake pad installation done in Palm Beach County... I dont have the time to do it and I really dont know how long it would take.. Any ideas?
Old Feb 22, 2006 | 12:19 AM
_jb's Avatar
_jb
Photographer
Do you want to install Brembos on a G35 that doesn't have them, or just put new pads on a G35 that already has Brembos?
Old Feb 22, 2006 | 07:46 AM
just new pads on my 04 6mt that already has brembos... is it pretty simple to do i looked at the DIY thread.
Old Feb 22, 2006 | 08:40 AM
Gilley's Avatar
You may want to use Hawk HPS pads in place of the stock Brenbo pads.
Old Feb 22, 2006 | 10:25 AM
98intrigue's Avatar
Originally Posted by DrRabbitFurHead
I could do it faster than I could tell you...
1. remove tire (loosen lugs, raise car, remove lugs, etc...)
2. remove hinge pin from the back of the caliper (this goes through the stainless steel rod that holds the pads in place.
3. slide the pin out.
4. repeat steps 2 & 3 for the other hinge pin and pin
5. wiggle both pads 1/2 way out.
6. use the pads to spread open the pistons
7. remove pads
8. insert new pads and break quiet goop
9. reinstall pins and hinge pins
10. reinstall tire
Repeat for the other 3 wheels.
I didn't reuse the backing plates on the rears... maybe you'd want to use 'em, maybe not...
You mean BRAKE quiet goop?
Do you think that could help me out with me squeeling brakes situation?
Jiggerjuice
Oct 5, 2015 02:33 PM
RA081024
Aug 18, 2015 07:03 AM
miata007
Aug 17, 2015 04:36 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
mushu
Jul 15, 2015 03:55 PM
