My ScanTool is getting an OE Code upgrade soon
Old Apr 30, 2006 | 05:13 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
From: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
http://www.autoenginuity.com/products-software.html
Enhanced interface for Nissan and Infinity 2000-2006 (Available in May of '06)2
Our enhanced Nissan interface supports code retrieval/resetting, sensors, and actuations from the engine, BCM, transmission, ABS, airbags, 4WD systems, and CAN systems. Coverage includes the Work Support configuration commands such as Target Idle Ignition Adjustment; with it you can permanently advance your ignition timing to gain few extra HP. Finally, we seamless integrate the CAN and non-CAN systems so that you won't have to worry about switching hardware to retrieve all the troubles codes from each module (including NATS V5.0 systems).
System Tests:
* Self-Diagnostic (Airbag)
* ECU Part Number (Airbag)
* Diagnostics Record (Airbag)
Work Support/Configuration Functions
* Target Idle Ignition Adjustment
* Target Idle RPM Adjustment
* Idle Air Volume Learn
Click here for a complete list of coverage: Nissan-specific sensors and systems.
1996-1999 support will require new stand-alone hardware sold separately.
Old Apr 30, 2006 | 06:41 PM
Audible Mayhem's Avatar
sweet
Old Apr 30, 2006 | 06:42 PM
djniknala's Avatar
cool
Old Apr 30, 2006 | 06:56 PM
Foo_G's Avatar
very interested int he fact that timing adjustments can be made. I ahev the OE extended codes for the ford/L/M and such adjustments cant be made.
Old Apr 30, 2006 | 07:54 PM
suaveyankees's Avatar
sweet
Old Apr 30, 2006 | 07:55 PM
djniknala's Avatar
You can only make them +/-2 degrees just like the consult. Otherwise you have to burn new code. The cypher tool does all this as well. Yes RLY!
Bill O'Really
Old Apr 30, 2006 | 08:40 PM
Foo_G's Avatar
Bill O'Really
Yeah I figured it wouldnt be RLY granular. I have asked the developer if it would follow the consult procedures but he has not replied yet.
Old Apr 30, 2006 | 10:54 PM
cool
Freeman186
Sep 6, 2023 10:07 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
Detailed Image
Sep 11, 2015 08:37 AM
Detailed Image
Sep 4, 2015 08:35 AM
