Goodbye G35!
Old May 2, 2006 | 09:44 PM
escobar929's Avatar
looks good, time to change the sig
Old May 2, 2006 | 11:34 PM
UFGatorG35's Avatar
Thanks for the congrats guys, yes those are Zenetti 5s (already on it, still up in the air about keeping them) and I cant believe I forgot to change the sig!
Whew! Now - what are the best springs for a slight drop and a stiffer ride? I actually liked my 04 a bit better (especially at high speeds) and want to tighten this one up without having to replace everything. Z springs? Teins?
Old May 2, 2006 | 11:39 PM
escobar929's Avatar
some 350z h-tech should do for now, later upgrade the shocks
Old May 2, 2006 | 11:46 PM
UFGatorG35's Avatar
How do these look? Clicky
Old May 2, 2006 | 11:59 PM
Finiti35's Avatar
FGC South Florida BOD
Get the H-techs for the Z, Stuart.. It's not worth going through the hassle of installing these and aligning the car for the .25" drop they give you (or thereabouts). Plus you have an 05 so your car is already lower from the factory...
Old May 3, 2006 | 12:03 AM
UFGatorG35's Avatar
Thanks for the input. Now, wheres the best place to grab them?
Old May 3, 2006 | 12:04 AM
escobar929's Avatar
get either 350z h-techs or 350z RS-R springs. the RS-R is more of an aggressive drop. but both are linear springs. all other G35 front springs are usually progressive <- not a good thing
Old May 3, 2006 | 12:11 AM
UFGatorG35's Avatar
Anyone used this site before? $143 here
Old May 3, 2006 | 12:16 AM
escobar929's Avatar
here are pics of a G w/ RS-R springs:
Old May 3, 2006 | 12:23 AM
Finiti35's Avatar
Why don't you try IAPdirect.com, they are a club sponsor and usually have the best prices (plus I'm not sure if a club discount applies?). Or just ask Dan (SFLG35), he can find them for you.
Did you call this a more aggressive drop, there's still a 2 finger gap in the back
Old May 3, 2006 | 12:34 AM
truplay8's Avatar
THE BATMOBILE
def go with RSR
Old May 3, 2006 | 10:50 AM
UFGatorG35's Avatar
Originally Posted by truplay8
def go with RSR
The coupe above looks good, but I've never been a fan of dropping too much. Anyone know off hand how much the diff is between the two?
Old May 3, 2006 | 11:06 AM
Finiti35's Avatar
The difference is mostly up front. The rear still looks pretty jacked up to me..
Old May 3, 2006 | 11:09 AM
UFGatorG35's Avatar
Hey Finiti, I only saw the Tein S on IAPDirect, not Tein H. I'm new to the whole springs thing, whats the diff?
** just found a couple good threads, decided to use the elusive search button **
Old May 3, 2006 | 11:44 AM
  #30
Finiti35's Avatar
The Tein S for the G are lower than the Tein H for the Z, but I'm not a fan of their spring rates. There is no reason for a spring to have lower spring rates than stock, even if it's for ride comfort purposes (a good damper should take care of that). Why don't you call IAPdirect, I wouldn't trust what's listed on their website
