vortech supercharger question
Old May 31, 2006 | 04:37 PM
M4Gunner's Avatar
Originally Posted by kzanard
I have the emanage ultimate set up. I also forgot to mention AAM return fuel system & 440 injectors.
nice, so i note that most of your mods are pretty simple installs aside form the emanage, id have giles do that. its nice to do the work yourself and save on labor.
Old Jun 1, 2006 | 06:50 PM
freezeg35c's Avatar
Originally Posted by booger
running Crawford cat ...I made 1.5 more psi...but less hp
So boog, what can i expect for psi going from stock cats to crawford?
Will i lose a bit? I also have the 3.12 and stillen exhaust.
Thanks.
Old Jun 1, 2006 | 08:16 PM
booger's Avatar
You for sure will gain some flow . But dont know how much psi will be lost . I wouldnt worry about the psi . The extra flow will gain you some whp
Old Jun 4, 2006 | 02:04 PM
Triji's Avatar
Ok, Booger... Since you are talking loosing a bit w/ Cats, what about Crawford Headers w/ the Vortech? I am goin FI real soon and have a Vortech on order... I have so far...
HKS exhaust, Crawford Plenum, K&N Typhoon CAI (bye bye), Lightweight pulley (took off),
I don't have alot of engine mods as you can see, the rest of my mods are in sig...
I most likely will stay w/ a low boost set up (yeah right) because this is my daily driver. I might go with the 3.12 pulley and that is about it.
Old Jun 11, 2006 | 12:37 AM
booger's Avatar
Any mod to open up the exhaust will gain you power . And it will cause the boost to be a little lower . A win win deal if you ask me
Old Jun 11, 2006 | 01:07 AM
Triji's Avatar
I am deciding between Crawford or Kinitex HF Cats... I am sticking w/ stock heads for now... PITA to switch out... 3.12 pulley. I am still deciding on changing out injectors and fuel pump or not... I will probably get her tuned w/ the stock set up and see how she reacts before I up them.
Old Jun 11, 2006 | 02:13 AM
Sundeviljay's Avatar
booger, is the walbro fuel pump a good idea for the vortech?
Old Jun 11, 2006 | 09:02 PM
Triji's Avatar
I know you asked booger but... I think the walbro would be more needed if you plan to go w/ a smaller pulley and larger injectors. I plan on keeping the stock Vortech set up w/ the 3.12 pulley unless I see it lean out too much.
Old Jun 11, 2006 | 09:30 PM
booger's Avatar
You will be able to run the smallest 2.87 pulley with the stock kit fuel system . Several guys are doing it . How safe is it ? I dont know
It all depends what plans you have . If you want to take the SC to as high of HP you can with it....yes it probably would be a good idea to change out the fuel system . If your just going to go with the 3.12 pulley...IMPO I would stay with what came with the kit and save your self some money .
You guys have to consider there are vendors on these sites doing thier job....selling stuff . They are the life blood of our parts and knowledge to take our cars to the next level and beyond . So suggestions to add parts to make your car SAFER than it is....are suggestions....and not all are needed to be SAFE .
Vortech designed a kit that is safe , and adding the next smaller pulley isnt going to take the system to the brink of being safe .
Old Jun 11, 2006 | 09:39 PM
Triji's Avatar
Thanks for all your posts and help booger! I can't wait to get my car back this week (hope Thurs or Fri)
Old Jun 12, 2006 | 03:14 AM
Dan_K's Avatar
Anyone blow their motor with stock kit and 3.12 pulley yet?
Old Jun 12, 2006 | 04:31 AM
sentry65's Avatar
yes people have
if you're not careful you can blow the engine with even the completely stock kit - or any kit
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
