Twin Tubro Set up one small one big, 300zx?
Old Jun 19, 2006 | 09:07 PM
SuperRacer's Avatar
I heard that the old 300zx twin turbo came with one small turbo and a larger one, im not sure if this is true, but the idea sounds good. The small turbo spools up really fast and provides boost until the larger one kicks in. Is this how the 300zx works.
I don't think there are any kits out there like this for our G's but I was thinking on piecing together my own turbo system, and i thought this would be a good idea, if it works, i know i have alot of research to do b4 i start buying parts and ripping apart my motor, your help is appreciated
Old Jun 19, 2006 | 10:29 PM
Tonys-G's Avatar
I had a 95 300zx and loved that car, but they came with two small turbo's both the same size, I have a buddy who had a Rx7 twin turbo and he tells me they came with one larger and one smaller turbo
Old Jun 19, 2006 | 10:30 PM
ttrank's Avatar
Grocery getter
The 300Z had the same size turbos from what I know.
Old Jun 19, 2006 | 10:34 PM
speedracerg35's Avatar
yes...93-95 rx7's were sequential (one small to spool up quickly, and one large for higher boost), but 300's had two that were the same size and kicked in at the same time.
Old Jun 20, 2006 | 01:16 AM
SuperRacer's Avatar
can a sequential turbo setup only be done on a rotary?
Old Jun 20, 2006 | 01:35 AM
Cloud_35's Avatar
No, it can be done on a piston engine. Correct me if I'm wrong but I believe the MKIV supra came with a sequential turbo system.
Old Jun 20, 2006 | 01:37 AM
SuperRacer's Avatar
yeah i just looked at that, the Supra's sequential setup is a little different though, it uses 2 of the same size turbos, and it sends all the exhaust to the 1st turbo and then, based on the load, it goes to the second, something like that its weird, i also read that the Porsche 959 had sequential turbos, but i havent been able to find any more info about it.
Old Jun 20, 2006 | 01:39 AM
ttrank's Avatar
Grocery getter
The new BMW 335i has sequential turbos.
Old Jun 20, 2006 | 01:43 AM
TwinTurboZ's Avatar
Doesn't make sense to put different size turbo's on a V-type engine. The Supra on the other hand has an inline-6 motor and from what I was told does have the sequential type turbo system, one bigger than the other.
300ZX TT = V-type
Supra TT = Inline-6
Hope that helps.
Old Jun 20, 2006 | 01:44 AM
SuperRacer's Avatar
yeah, the 335i is a nifty setup it has 2 small turbos, with virtually no turbo lag, the car reaches peak HP, like 306hp, @ 1400RPM then flat lines all the way, its pretty cool.
But the setup i want to do it to have a large turbo where i can get some good HP, but since its so large it will have lag, and i wanted to fix that by using a small turbo, so off the line the car would run off the small turbo, untill the big one kicked in and eventually takes over.
If u look at the 335i, it uses the 3.0l engine found in the 330, but turbo it, only adding about 47hp if i remember reading correctly, if i turbo i want it to be more than 47 ponies
Old Jun 20, 2006 | 02:42 AM
i'm pretty sure you can only put sequentials on inline or rotarys. the positioning of the turbos in sequence wouldn't work with a v-engine. each bank of cylinders would not be able to feed separate turbos...it wouldn't make sense to have them boost at different pressures.
Old Jun 20, 2006 | 07:42 PM
SuperRacer's Avatar
well, what if i did it smilar to a single turbo set up, where the turbo takes exhaust from both manifolds, one on each bank of the V, and then split it again?
Old Jun 21, 2006 | 03:34 AM
TwinTurboZ's Avatar
Sounds like a lot of expensive custom work to me. The best thing you can really do is get a good exhuast system to alleviate the back pressure so the turbo's can spool up quicker, but hey im no expert. I believe superchargers produce a smoother power band; might want to look into that.
Old Jun 21, 2006 | 07:52 AM
350Zed's Avatar
It might reach peak TORQUE at 1400RPM, but reaching peak HP at that number of revs does not jive:
bhp = torque x rpm/5252
306 = torque x 1400/5252
torque = 1148
1148 lb-ft of torque? Errrrrrrr....... no
Old Jun 21, 2006 | 11:21 AM
SuperRacer's Avatar
torque = 1148
Sorry my bad, i meant peak TQ not HP
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
JG_G35
Accessories
Feb 25, 2016 01:44 AM
Team STILLEN
Aug 10, 2015 08:17 PM
Chattzx
Jul 17, 2015 11:23 AM
