Does anyone here have the APS ST or TT WITHOUT an engine failure?
Old Jun 24, 2006 | 04:16 PM
exagorazo's Avatar
If so, could you post a reply giving the pertinent details:
Does your engine have stock internals or upgrades?
If the engine was upgraded, what was done to it?
What extras have you installed for the turbo in addition to the kit?
What boost level are you runnng?
What is your WHP (only if known from a dyno run)?
About how many miles have been driven since the turbo install?
What octane gas do you use?
What octane gas was the engine tuned for?
What is typically the highest rpm's you run?
Who did the most recent tune?
Are you aware of any cooling issues with your engine?
I'm looking for ONLY personal experience here. If YOU do not have an APS turbo on your car, please do not post a reply. Please do not post information about a friend's car or one you have heard about. Please do not post references to other threads or forums (like my350Z.com).
Thanks very much!!
Old Jun 24, 2006 | 04:43 PM
EricIsKlumzyee's Avatar
dont own one but know a few friends from an autorized APS dealer also work on a friends car with a ST APS Kit (before the new fuel system was released) if you have a specific question about the kit itself please PM me and i'll do my best to answer it. but most of the question above depends on the owner and how far he wants to push his motor. most of the guys i know run it very safe while others tell the tunner to push it as far as it'll go..
heres some questions answered based on the auto st g35 coupe
- bone stock internals
- n/a
- gauges
- 4-6psi
- 278whp un-tuned 338 "quick" tuned
- last time i checked 3,000
- 91 pump gas
- 91 pump gas
- 7k
- gt motorsports ontario, california
- stock thermostat, stock radiator, stock fan, everythings stock.. no cooling issues
Old Jun 24, 2006 | 06:34 PM
Ginsengboy's Avatar
I have an APS TT with the APS plenum installed. I have stock internals with about 8lbs of boost. Driven about 7000 miles without any problems. I use 93 octance fuel on the 91 octane map. Car is not tuned yet, but plan on doing it sometime this month. It's my daily driver so i rarely drive it hard.
Old Jun 24, 2006 | 10:06 PM
Orlando333's Avatar
Thanks very much!!
I HAVE AN APS ST PURE STOCK ENGINE RUNNING AT 8.5 PSI ON 91 OCTANE. HAVE ABOUT 20000 MILES ON THE KIT
AFTER ORIGINAL INSTALLATION AND TUNE, DID 330 WHP -- I HAVE AN AT
GOT A KINETIX SSV AFTER 3K MILES AND THEN A NEW TUNE; NOW DOING 379 WHP. BELIEVE COULD DO MORE IF I SWITCH OUT MY EXHAUST -- CURRRENLTY HAVE A BORLA WHICH I BELIEVE CAUSES A BACK UP
ABSOLUTELY NO COOLING ISSUES WHATSOEVER; REGULARLY MAKE WEEKEND TRIPS FROM LA TO MY WEEKEND HOUSE IN PALM DESSERT (ITS ABOUT A 110 OUTSIDE RIGHT NOW) AND BEAT THE **** OUT OF THE CAR REGULARLY DOING OVER 125 ETC.
WORD OF ADVICE -- IF YOU BUY THE KIT GO TO AN AUTHORIZED APS DISTRIBUTOR TO INSTALL WHO KNOWS HOW TO TUNE THE UNICHIP OTHERWISE YOUR ARE GOING TO BE SOL
IF YOU WANT AN APS KIT; CALL CHRISTIAN AT BRAINSTORMING IN LA; THEY MAY POST HERE SO DO A SEARCH
BRAINSTORM DID MY INSTALL AND ARE THE ONLY TUNER WHO HAS TOUCHED MY CAR SINCE. (THEY DID THE TUNING ON THE FF3 CARS.)
YOU MAY PM ME FOR MORE QUESTIONS.
IF YOU GO FI; YOU ARE GOING TO HAVE SET SOME CASH ASIDE FOR INCIDENTALS, INCLUDING FUTURE TUNES ETC. ITS THE PRICE YOU PAY FOR MORE HP.
Old Jun 24, 2006 | 10:47 PM
IvoryGT-V's Avatar
I have the greddy TT completely stock internals, top speed test pipes, and evo2 exhaust system. I have had it for about 2 months and about 1500 miles. No problems and pushing about 365whp estimated not dynoed yet.
And loving it.
Old Jun 24, 2006 | 11:56 PM
bullitproof's Avatar
APS ST
Does your engine have stock internals or upgrades?Stock internals
If the engine was upgraded, what was done to it?N/A
What extras have you installed for the turbo in addition to the kit?AAM plenum spacer, Jic exhaust, utec, sard pressure regulator, forged actuator
What boost level are you runnng?8(low boost actuator only) 9.5(utec boost controller)
What is your WHP (only if known from a dyno run)?420whp(93oct), 440(C-16) dynapack dynometer
About how many miles have been driven since the turbo install?3000
What octane gas do you use?93octane
What octane gas was the engine tuned for?93 and C-16
What is typically the highest rpm's you run?Usually 5000, ocasionally spinning it to redline( no need cuz it makes so much power)
Who did the most recent tune?CarVersion2 in Delaware
Are you aware of any cooling issues with your engine?Nope
Hope that helps. If you have any more questions about the kit, PM me
Old Jun 25, 2006 | 02:49 PM
PhxBlue's Avatar
Polyester Pileup FTW!
APS ST
Does your engine have stock internals or upgrades? Stock
If the engine was upgraded, what was done to it? Crawford Plenum
What extras have you installed for the turbo in addition to the kit? Gauges. Stillen front bumper for better airflow to the intercooler
What boost level are you runnng? 9psi
What is your WHP (only if known from a dyno run)? 340 (dynodynamics dynamometer)
About how many miles have been driven since the turbo install? 9,000
What octane gas do you use? 91
What octane gas was the engine tuned for? 91
What is typically the highest rpm's you run? 6500
Who did the most recent tune? DynoComp in Scottsdale,AZ
Are you aware of any cooling issues with your engine? None whatsoever and I live in AZ where its 110+ everyday in the summer
Old Jun 26, 2006 | 10:48 AM
marchesano's Avatar
www.g35tt.com
APS TT
Does your engine have stock internals or upgrades? 9000 Miles on Stock internals
If the engine was upgraded, what was done to it?I just upgraded internals (Arias extreme pistons, rods, studs, fordge, sleaved, everything else
What extras have you installed for the turbo in addition to the kit? APS Plenum, Pro 1 test pipes with Exhast cutouts, APS 2 1/2" exhaust, Unothodox pulleys, kenstyle body kit for more air, NX Intercooler spray
What boost level are you runnng? 8 PSI
What is your WHP (only if known from a dyno run)? 431
About how many miles have been driven since the turbo install? 9000
What octane gas do you use? 93 or 94
What is typically the highest rpm's you run?6500 when racing, daily driving might hit about 4500 max
Who did the most recent tune? MRC Motorsports
Are you aware of any cooling issues with your engine?none, but I did not do autoX in the summer heat yet, but wil be upgrading the radiator and installing an oil cooler
Old Jun 30, 2006 | 12:13 AM
exagorazo's Avatar
Off Topic Posts/Replies
Rather than hijack this thread, could everyone please keep off topic posts/inquiries as the subject of a PM rather than a post that is something other than owners of APS turbos reporting their personal experience?
Please don't post to this thread if you are not reporting personal experience with an APS turbo on YOUR car. Thanks.
Old Jul 7, 2006 | 11:45 PM
exagorazo's Avatar
bump
Old Jul 17, 2006 | 01:47 PM
ttrank's Avatar
Grocery getter
Bump
good thread!
Old Jul 20, 2006 | 11:22 PM
Ginsengboy's Avatar
I posted before, but i just got my dyno results today.
APS TT
Does your engine have stock internals or upgrades? stock internals
If the engine was upgraded, what was done to it? N/A
What extras have you installed for the turbo in addition to the kit? APS plenum
What boost level are you runnng? 8lbs
What is your WHP (only if known from a dyno run)? 387 whp
About how many miles have been driven since the turbo install?7K
What octane gas was the engine tuned for? 93
What is typically the highest rpm's you run? 5500
Who did the most recent tune? V2
Old Jul 21, 2006 | 01:52 AM
A little off topic but APS has announced a price drop on the single turbo kit 8/1/06 through 12/31/06. The new price is $4,995.
Old Jul 21, 2006 | 11:14 AM
BrianlG35C's Avatar
Ohio G Club Member
APS TT
Good move, don't go any higher than your current whp. Should be safe for a long time on stock internals.
Old Aug 11, 2006 | 04:34 PM
exagorazo's Avatar
bump
