Huge Problems! Dud Stillen Sc?
Old Jul 2, 2006 | 12:37 AM
Skyline_G35's Avatar
English dude, English
The belt broke!!!! I lost power steering and my battery light came on!!! I'm 70 miles from home. Is there any shops open on Sundays???
Old Jul 3, 2006 | 04:35 AM
nate4598's Avatar
Originally Posted by superchargedg
they prolly didnt tighten up the power st belt enough.it will feel tight to the installer but has to be tighted even more.dont use goodyear gator belts,only use the gates they dont stretch as much.
Stillen just have a new prolly...(which is wider & lighter). I just visit them last friday and they replaced it. With this new prolly, Stillen said that the blower belt should last longer
Old Jul 3, 2006 | 09:28 AM
mokc's Avatar
I'm going in this Wed to get my car dynoed. What is it that they have that is new? What is a "prolly"?
Thanks!!
Old Jul 3, 2006 | 10:24 AM
superchargedg's Avatar
Thanks!!
he meant pulley,i use prolly instead of probably.
Old Jul 3, 2006 | 04:31 PM
malx's Avatar
Glad to hear everything is okay!
Show us some pics!
Old Jul 3, 2006 | 09:15 PM
I'm confused. I'll call Stillen, but I don't know what to ask for. explain it again please. Thanks.
Old Jul 4, 2006 | 12:42 AM
mokc's Avatar
+1...which pulley are you referring to? Are we talking about the idler pulley?
Old Jul 4, 2006 | 02:02 PM
mraturbo's Avatar
PLEASE PM.
Have done many Stillen blowers. Belt and pulley problems are frequent. Goes with the territory I guess.
Good-luck.
M
Old Jul 4, 2006 | 05:15 PM
ttrank's Avatar
Grocery getter
Jon,
If they just replaced your belts then they will need to be tightened after a little driving because new ones stretch a little.
Old Jul 5, 2006 | 02:43 AM
nate4598's Avatar
Sorry...I don't know what it called...but guess it's the silver tensioner for the 4 rib belt
Old Jul 7, 2006 | 02:12 PM
ttrank's Avatar
Grocery getter
Stillen did have a silver tensioner that was "auto". They changed to a manual tensioner due to belts slipping.
Because of the space limitations they had to use that small 4-rib belt which needed to be bigger so it will wear out semi-often. Here in Phoenix I figure I will need to change it at least every 4 months.
Old Jul 7, 2006 | 02:14 PM
ttrank's Avatar
Grocery getter
On the other issue, I took off the idler pulley and re-lubed it a couple weeks ago with penitrating lube then replaced my belt, drive it for a couple days and tightened it. No problems or squeels since. That was the first noise I have had with it so far.
Old Jul 7, 2006 | 04:09 PM
thats wierd cause i still have the old spring loaded tensioner,i got mine late 03 and luckily havent had any belt slippage.but your right about the 4 rib belt,i get about 6 to 9 months outta mine.
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
cmesidewayz
Sep 29, 2015 09:28 PM
Jnm07
Sep 5, 2015 01:16 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
kevintandmd
Sep 3, 2015 06:41 PM
