Vortech Supercharged.now what?
Old Jul 9, 2006 | 03:04 PM
Sportcoupe35's Avatar
I have a 2006 G35 coupe 5AT with the Vortech supercharger.
Its everything out of the box.
I have the JWT oil pan spacer and new plugs.
I'm planning on getting the Fast Intentions High Flow cats.
What else can I do to my engine to up the power (I don't want to do anything to much...just small stuff to bring all that power together).
Some people have put different pullies....MREV Motordyne plenum spacer...UTEC are some of the things that I've seen people do ontop of their F/I kits.
Old Jul 9, 2006 | 03:22 PM
truplay8's Avatar
THE BATMOBILE
exhaust, pulleys, test pipes, and UTEC
Old Jul 9, 2006 | 05:03 PM
superchargedg's Avatar
valve body upgrade.
Old Jul 9, 2006 | 06:42 PM
Xman's Avatar
5AT - VB upgrade a must + TC upgrade. Also consider an additional tranny cooler. If you're going smaller pulleys also consider larger injectors and a fuel return system.
Old Jul 9, 2006 | 10:14 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
++1
Old Jul 9, 2006 | 10:53 PM
sentry65's Avatar
don't forget final drive and better tires
Old Jul 9, 2006 | 11:08 PM
KenK2's Avatar
The Pole
Gotta get the UTEC for EM when doing all that upgrading.. UTEC or GReddy, just get something!
Old Jul 9, 2006 | 11:16 PM
Texasscout's Avatar
You didn't say whether you had it "tunedJ", that would be the next step.
Old Jul 10, 2006 | 01:03 AM
G.Ride's Avatar
GREDDY!?!?!?
Unichip or UTEC, HKS FCON VPRO if you can get it.
Old Jul 10, 2006 | 01:51 AM
KenK2's Avatar
The Pole
Originally Posted by G.Ride
GREDDY!?!?!?
I agree with ya but at least get something...
Old Jul 10, 2006 | 08:37 AM
Yes, I already had it tuned after they did the install.
So you guys think that I must get a Valve Body Upgrade and UTEC?
Where can I get these?
Old Jul 10, 2006 | 09:06 AM
Xman's Avatar
You can get the valve body upgrade from SGP Racing. You'll have to ship it to them. Takes about a week.
You can get the UTEC from turboxs.
Old Jul 10, 2006 | 12:54 PM
GXCLUSIV's Avatar
You can get both VB upgrade and Utec from Sharif at Forgedinternals.com.
Old Jul 10, 2006 | 01:00 PM
G.Ride's Avatar
what are the thoughts on the Oil pan spacer Vs. the APS oil pan itself?
Old Jul 10, 2006 | 02:35 PM
Dr_jitsu's Avatar
Someone said on another thread that test pipes won't work on SC unless running huge (15psi) boost. Does this make sense?
Also, you MUST get good eng. man. The UTEC is excellent. The Fcon V-pro is GOD is you have 3.3 K for eng. man. Spacer and exhaust will also help.
If you keep the power below 350 whp you won'y NEED new internals is you drive snsibly.
