3rd belt snap but 1st in this location
Old Jul 16, 2006 | 09:16 PM
Skyline_G35's Avatar
English dude, English
I can't believe this. I maybe have put 1000 miles on this car since the SC went on and I went to show my friends neighbor and I opened the hood and the 4 rib belt to the SC was shredded and only 2 ribs were left. I pulled it off and put the new one on. This was the first time that this belt broke but it is the 3rd new belt that I have had to put on since this SC has been on. This morning I started the car and got an instant squeak out of a belt. I'm not sure, but maybe I need to tighten up this new belt.
Old Jul 16, 2006 | 10:17 PM
NJlakeshoreG's Avatar
possible crooked pulley...or warped pulley....or u have rats n small mammals living in ur engine bay....
i dunno...just a few thoughts...
Old Jul 16, 2006 | 10:26 PM
GLuXuRy's Avatar
^^^hmmm good idea... you think you could put a dial indacator on the pulley and see if it is warped?
LOL on the rats.
But my patience for this is running real thin.
Old Jul 16, 2006 | 10:44 PM
rookie's Avatar
Weird, I didn't lose any belts during the 7500 miles I had the Stillen. Is your idle tensioner pulley on the supercharger black or silver? I know someone with a black one and shreds belts too.
Old Jul 17, 2006 | 12:59 AM
its black, but silver is showing through from paint wear.
Old Jul 17, 2006 | 01:02 AM
G.Ride's Avatar
are there any sharp nubs on the pulley???
Old Jul 17, 2006 | 01:21 AM
nope. I'm just thinking that the belts are tightened down correctly. But I don't know.
Old Jul 17, 2006 | 01:24 AM
G.Ride's Avatar
well do they look like they are shearing?? Are they stretched?
Old Jul 17, 2006 | 01:30 AM
rookie's Avatar
Maybe too tight? Have a picture of how tight it was?
Not sure if this helps
Old Jul 17, 2006 | 01:57 AM
wa2good's Avatar
This is a common problem associated with these SC's unfortunately. I have been known to go through a couple belts in one track day.... all's you can do is make sure the pullies are lined up good (use a shim kit if you have to), be sure not to over-tighten the belts, and keep a stock of about 3-5 belts with you at all times (along with the tools to change it.....Hahaha....LOL
Old Jul 17, 2006 | 09:14 AM
superchargedg's Avatar
man i feel bad for you,in the over 20,000 miles with this kit.i have only had to replace the 6 rib and 4 rib belts just once.but i did have to retighten the rerouted p/s belt 3 times.stillen does have a shim kit for these problems,call and ask for sam and descibe all the belt problems,hell figure it out for you.good luck.
Old Jul 17, 2006 | 11:22 AM
Mine doesn't look that tight. That tensioner looks like it is almost touching the other pulley. Man, maybe I need to tighten mine up even more.
Old Jul 17, 2006 | 12:29 PM
Q45tech's Avatar
Consider that the sc draws [parasitic loss] around 20-25 HorsePower and this gets transmitted thru the belt vs say 5 HP for the AC belt or alternator or PS.
In theory the belt should be twice as wide to get oem type longevity.
When these type superchargers/belts were used on GM V6 the redline and HP peaks occurred at much much lower rpms.
Consider a redesign if you want belt reliability out to 30,000 miles or limit rpm.
Old Jul 17, 2006 | 01:30 PM
ttrank's Avatar
Grocery getter
That is about how tight mine is.
Jon - I am sorry you have had so many belt problems with your kit. It is not normal. I feel for you.
ZoominG35
Dec 6, 2015 03:11 PM
jbmw002
Drivetrain
Aug 27, 2015 03:01 PM
sofa king
19 Inch
Aug 9, 2015 04:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
