Turbo Cams for Revup (05' G35)
Originally Posted by vipv35
is it possible to have the stock cam reground to better suit the turbos?
I had reground stock cams on a cobra (about 9 years ago) before anyone had blank billets. They worked great, but you need to use shims because in order to increase lift and duration from the stock cam, they have to reduce the base circle of the cam.
Essentially, the cam is physically smaller, but you it is done in a way so that you have more lift and duration. Lift and duration are all realative to the base circle.
laksjd84
07-24-2015 05:12 PM
