FI'd BEAST get's DYNO'd
Old Sep 9, 2006 | 12:10 AM
ISMSOLUTIONS's Avatar
Originally Posted by trey.hutcheson
I can't remember the exact thread, but it was confirmed on my350z that the rod bolts changed on the revups. I didn't exactly know the implications, so I asked, and was told that the mere act of changing the bolt locations strengthened the conrods.
You got it right...
The bolts are changed and stronger in that block. The cams are also a different profile, giving the car more top end, but less torque down low.
They UPPED the HP up top...so RevUP...
Rick
Old Sep 9, 2006 | 12:20 AM
Originally Posted by GT-Ron
I found this comment interesting and would love for you to expand upon it, to the extent that you can.
Sure -
The overall result of a good port and polish and cams with valve train, result in virtually the same HP results as the custom matched heads did, with the same cams and valve-train match - within 2%.
For a higher compression motor build however, if you did the full bottom end as well and are going for mass HP, the heads make more difference in the realm of 19% HP increase over the port and polish only.
They breathe much better, hands down, but if the car can't process or even produce a level of combustibility that they will provide, it's a waste.
Save the additional $3000-$4000 on the bare heads and buy the blower or turbo kit - or enhance that with a proper fuel system, or transmission/VB kit/clutch, maybe even gears or a tune and bottom end strengthening, or even bling...hey maybe even a vacation! OR use it for a downpayment on a daily driver so you can really build the $hit out of the car
Rick
seagrasser
May 3, 2022 09:43 AM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Blue Dream
Dec 5, 2015 10:56 AM
