clutch/flywheel recommendations for ST.
Old Sep 19, 2006 | 09:46 AM
Eagle1's Avatar
Originally Posted by Deang35c6
Eagle1,
I am running the 14lb JWT flywheel with the stock clutch. It's working pretty good with my 350 rwhp and 310 ft/lb SC G35. Turbos deliver power more abruptly and have more torque, so it might not be enough. They are noisey SOBs though.
Thanks for the clarification, Dean, most appreciated. The stock dual mass flywheel is very quiet, and the Nismo single is still quite good, probably the way the 6mt should come in the first place in a performance package set up. But when you go down to the JWT and others you will get that "cement mixer" grind or rattle noise. Nothing wrong with it, just in the background at idle. If it is noxious you can always depress the clutch at the stop and it will go away, and if you lift softly in neutral it will often stay balanced enough to be quieter. Of course once engaged it is quiet.
I think JWT did a fine job picking the 14lb weight. The ATS is about 10 lbs and that is certainly as light as I want to go. The Tilton is 8lbs, and that is very nutty to drive on the street. I have not tried the Tilton with their so called "street clutch" so maybe that solves the challenge with the first set up they released a couple of years ago.
Old Sep 19, 2006 | 12:06 PM
MIAPLAYA's Avatar
Originally Posted by beangrower
^any online stores to recommend for that clutch?
www.z1auto.com has them for a great price.
Old Sep 21, 2006 | 08:52 PM
636Racer's Avatar
+1 ACT, they['re very capable clutch systems. ask for Adam at Z1 auto. one of my coworkers bought a few things from them...just for us hawaii people, we have to call. but that's no biggie.
Old Sep 21, 2006 | 09:03 PM
2006_G_coupe's Avatar
Has anyone tried the ur cluth and flywheel togther?
Old Sep 25, 2006 | 12:29 AM
G-Mann's Avatar
im getting the ACT heavy duty clutch installed tuesday. then after that in the next week or so im puttin on the turbonetics kit. JoTech is doin the installs i went down there yesterday and talked with them for about an hour, they said for my goes right now (390-410rhwp) the ACT is plenty for me. and he didnt recommenc the JWT becuase it didnt have a damper on the flywheel or soemthing like that, so taht makes shifting with the JWT a little more unsmooth. im pumped
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
f22raptor
Mar 18, 2016 08:50 AM
dseet
Oct 11, 2015 12:40 AM
RWDguy4238
Sep 30, 2015 12:13 AM
Detailed Image
Sep 28, 2015 07:04 AM
