Prochargers Advertised Gains
Old Oct 22, 2003 | 04:15 AM
gdupg35's Avatar
I'm curious as to why Procharger lists the horsepower gains for the 350z at 55% to 60% and the G35 at only 45% to 50%.
Seems like I smell BS, but I could be wrong. What do I know? (Not much apparently)
Old Oct 22, 2003 | 05:34 AM
RaySur350GT's Avatar
Re: Prochargers Advertised Gains
They put a 5 PSI pulley for the G35 kit and a 7 PSI pulley for the 350Z kit.
- Don't argue with idiots. They will bring you down to their level and beat you with experience.=P-
Old Oct 22, 2003 | 03:39 PM
Need4Speed's Avatar
no, actually according to the ati tech i talked with them last
week, both kits are shipping with the same pulleys. I had
them double check my part numbers. they blamed it on g's
ecu. i think it maybe that but mostly the restrictive inline
air filter which the z's don't have. i plan on replacing that
asap and see if my boost levels go up...
03 G35C auto nav, alum. pedals, grounding kit, ultralight battery, Z tube (x), crawford plenum, RT cats, borla, ATI Procharger!
Old Oct 23, 2003 | 12:19 AM
jdove's Avatar
If you can get a PSI differential when measured before and after the air filter under boost @ WOT, then that would certainly be the main reason for softer claims with the G kit. If the filter is really as restrictive as it sounds it may actually drop 2psi or more. If this all really is the case , it reinforces my thoughts that ATI cheesed out on the G-kit, and should resolve the filter placement and other plumbing issues (ie. crankcase breather inlet)..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
magnetism80
Jan 27, 2016 12:57 PM
Usman Ali
Oct 4, 2015 08:23 PM
thechitoguy
Oct 1, 2015 05:25 PM
9tray turbo
Sep 29, 2015 10:22 PM
