5AT w/ tranny coolers chime in.
Old Oct 9, 2006 | 09:49 PM
roneski's Avatar
Devil's Advocate
Sorry that I missed this thread but it looks like most everything has already been said. Just got done installing a cooler on a friends G who recently had his turbo installed.
Old Oct 9, 2006 | 10:02 PM
rcdash's Avatar
Ok, just to make this thread longer, what about inline transmission filters? Worthwhile? Or just another point of failure?
Old Oct 9, 2006 | 11:35 PM
rookie's Avatar
Originally Posted by rcdash
In series, after the OEM, in front of the radiator and not behind the condenser - just what i needed to know...
Thanks!
(I wasn't planning on adding a temp gauge, just using the CIPHER tool as there are apparently two temp sensors there... hope it's an ECM and not TCM parameter though as CIPHER doesn't "do" TCM yet).
Mine is in series, infront of the radiator/condensor. I don't recall a transmission temp in Cipher, I thought the only temps I saw were coolant and air intake. I know there's a temp sensor on the VB.
Old Oct 9, 2006 | 11:55 PM
roneski's Avatar
Devil's Advocate
I picked up the Amsoil version. I figure that it can't hurt. I haven't installed it yet though.
Old Oct 10, 2006 | 07:26 AM
rcdash's Avatar
I read some good reviews of MagneFine - it is a simple inline installation on the return line. The 2 good pts about it are the magnet and the clog bypass valve, which ensures flow even if the filter block up.
I purchased it from this US distributer for $19 (apparently they are an Australian co.).
Old Oct 11, 2006 | 10:01 PM
Xman's Avatar
I've followed Roneski's lead wth the B&M cooler. I've been watching/smelling ATM fluid for about 3K miles now after VB upgrade/TC upgrade since I went SC. No problems FWIW.
Old Oct 13, 2006 | 09:06 PM
roneski's Avatar
Devil's Advocate
Must have been smoking crack that day, I actually have the B&M version. Probably going to install it tomorrow.
http://store.summitracing.com/partde...5&autoview=sku
Old Oct 13, 2006 | 09:53 PM
ballisticus's Avatar
These aftermarket coolers can never hurt (unless they spring a leak), but know that they really are unnecessary except in the most extreme service. This JATCO unit is very understressed behind the VQ35 and the Matic-J ATF is a very oxidation resistant, full synthetic lubricant. Unless you frequently do 90+ MPH runs over southwest mountain grades, tow a trailer (LOL!), or autocross the car, the 15K ATF change interval for severe service is adequate.
However, that B&M remote filter is definitely a good idea. Especially with a good Purolater PureOne filter spun on there. That fluid will be crystal clear.
Old Oct 14, 2006 | 04:20 PM
roneski's Avatar
Devil's Advocate
I'll be using a Wix 51515 filter. Both are awesome though.
Old Oct 14, 2006 | 06:04 PM
MardiGrasMax's Avatar
Where in line would you guys the filter? How often would you change the filter, 10-15k? Any concern on pressure drop with a cooler and filter.
Old Oct 14, 2006 | 07:11 PM
n2fooz's Avatar
That's a little different than what Q45TECH seems to be saying. His posts make me think that my tranny is living on borrowed time.
Old Oct 14, 2006 | 07:43 PM
roneski's Avatar
Devil's Advocate
My tranny shifts so hard, a pressure drop might be a good thing.
Old Oct 14, 2006 | 09:02 PM
rookie's Avatar
With or without a VB?
Old Oct 14, 2006 | 10:29 PM
roneski's Avatar
Devil's Advocate
With the VB.
Old Oct 14, 2006 | 10:41 PM
  #30
rookie's Avatar
hmm. When will you be in socal next? I've read of varying VB shifting. I have the forged one and it is only rough when I'm heavy on the throttle. Some have said they can not do 1-2 or 2-3 manumatic shifting (no matter what throttle position) smoothly.
