vortech intercooler upgrade??
Old Nov 1, 2006 | 01:44 AM
lastsongforagirl's Avatar
is there such a kit out in the market? mine is kinda beat and am looking to get something better...any ideas where?
thanks
Old Nov 3, 2006 | 12:50 PM
SFLG35's Avatar
FGC President
i have a spearco intercooler that was made specifically for a vortech kit. it fits unnderneath the bumper support and will fill the whole opening of a greddy bumper. i can post pics of it later tonight if you would like. its never been used. was goin to get a vortech kit so i got the intercoller for it but then never got hte kit and the ic has just been sittin in the garage
Old Nov 3, 2006 | 02:29 PM
SFLG35's Avatar
FGC President
it was specially made
here are pics
Old Nov 3, 2006 | 02:32 PM
SFLG35's Avatar
FGC President
the hoses are silcone hoses like the samco hoses
Old Nov 3, 2006 | 05:04 PM
booger's Avatar
Thats a pretty long IC . But it may not flow as much as the stock IC . From what Ive been told and read , a longer IC cools better , a taller - wider IC flows more . Look into a Icevex IC , well built and half the price of Spearco or a Greddy
Old Nov 3, 2006 | 05:16 PM
SFLG35's Avatar
FGC President
yeh it was made long to fill the entire opening of a greddy bumper
if anyone is interested let me know
im not lookin for much i just want to get rid of it. it cost like 550 for the whole thing i just want it gone
Old Nov 4, 2006 | 10:01 AM
Q45tech's Avatar
Important to BALANCE the air flow pressure drop with the temperature drop as 1 psi = 6.8% density change and 11F = 1% density change..........another 1/4 psi restriction needs another 19F temperature drop to just be equal.
However one must calculate the fuel knock index vs temperature so it may be only half as bad.................cooler is better than psi for street gasoline.
Old Nov 4, 2006 | 12:54 PM
sentry65's Avatar
i think the stock IC is up to the task for quite a lot of power, I wouldn't change it until you're making some really huge power and your intake temps really are rising enough to the point that you need the air to be a lot cooler.
STI's intercoolers are smaller and they're handling 14 psi just fine
Old Nov 13, 2006 | 03:19 PM
TurboTim's Avatar
That intercooler is a tube and fin core which is something I dont think Spearco sells.We build all kinds of intercoolers using Spearco cores so I know we could come up with something that is much better then the Vortech intercooler that comes standard withthe kit. Shoot we can even supply some real mounting points on our design When we installed the Vortech system on a customers car I was in awe that there was no real mounting tabs for the intercooler. It just laid on some flat pieces of aluminum.Cheesy!
tim
Old Nov 13, 2006 | 03:21 PM
TurboTim's Avatar
The Vortech intercooler is good for about 500WHP efficiently. After that,the efficiency drops and you start to injest very hot air into the motor.
Old Nov 13, 2006 | 04:07 PM
sentry65's Avatar
that sounds right to me, but are there many people running over 500whp on a vortech?
I know of one guy...he's making around 510whp
and you can always add water/meth injection which does more than just cool the intake charge, but also helps prevent detonation and steam cleans the engine internals
Old Nov 13, 2006 | 08:56 PM
TurboTim's Avatar
Yes people can make over 500WHP with the Vortech intercooler but it is not as efficient as a larger intercooler would be.So if you go to the larger intercooler you will make more horsepower with no other changes except for some minor tuning adjustments. We would be willing to make a replacement intercooler specifically designed for the Vortech S/C system if people were interested.
Tim
KruZZe
Feb 27, 2023 05:04 PM
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
9tray turbo
Sep 29, 2015 10:22 PM
