Dealer said they'll warranty my S/C install, too good to be true?
Old Nov 11, 2006 | 01:11 PM
ma_sha1's Avatar
Went to my local dealer & talked to the machanics, John @ Bill Dodge infiniti,
Not only he said he could instal my S/C, he belive I'll still be under warranty
for my Engine & transmission as long as I get it installed there.
John usually does boring jobs as samo same fixing of stock cars,
so he seems excited to install the SC for me. Sounds too goo to be true?
He is not the service manager, So his word is not final.
Should I confirm it with the service manager? I am afraid he will say no.
Or should I just have John do it & avoid talking about the warranty subject,
but expect him to back me up if somthing goes worng?
Old Nov 11, 2006 | 01:17 PM
GEE35FX's Avatar
You should talk to the SM, the mechanics word won't pull any weight if you lunch a motor down the road.
Old Nov 11, 2006 | 02:03 PM
roneski's Avatar
Devil's Advocate
Get it in writing.
Old Nov 11, 2006 | 05:02 PM
GreenGoblin's Avatar
The goblin resurrection
sounds good that is sweet that they will warrenty that let us know
Old Nov 12, 2006 | 01:42 PM
Q45tech's Avatar
Your warranty is with Nissan and the dealer cannot modify, change, or extend/reduce coverage.
They can however issue you a written document agreeing to warranty things Nissan does not agree to warranty.
Or they can hope to fool Nissan if anything happens.
Old Nov 12, 2006 | 03:34 PM
da mayor's Avatar
if it's through stillen they do offer a 3/36k warranty. as long as you have some sort of documentation then it should be fine but i'm sure there will be disclaimers if you turn up the boost or adjust something that the dealer did not do. go for it.
Old Nov 12, 2006 | 03:49 PM
havocwreaker's Avatar
Originally Posted by roneski
Get it in writing.
I totally agree with this statement. Make them write it on an estimate with the parts and labor charge. Make sure it has your car's Vin/Model on there.
My E46 had a Dinan CAI with software Upgrade done at the dealer. They made an entry on the service history stating that the car is still under warranty as well as the parts.
I like to think that no one cares about me as much as I do. Meaning, the service mechanic is not going to jump through hoops to make sure you are warrantied. Make sure you don't get scammed.
Old Nov 12, 2006 | 05:45 PM
ma_sha1's Avatar
Thanks, Guys,
I'll give it a try. But I am not confident that they'll put it down in writing.
Old Nov 13, 2006 | 12:08 AM
Mr_pharmD's Avatar
usually they make u sign a paper saying they are not responsible for damages to the engine bc this is off road use only. The only warranty u have is labor (loose belt etc) and that is only with that dealership.
Old Nov 13, 2006 | 12:49 AM
ttrank's Avatar
Grocery getter
Get it in writing from them. At least that way you have something to fall back on if problems come up.
Old Nov 13, 2006 | 02:42 AM
Ramon's Avatar
No matter who you talk to, get it in writing!!!
I had my CAI and my exhaust installed at the dealer!! I will be 100% honest with you... nobody mentioned anything about warranty issues! (I probably should have asked them). But, mine were simple mods.... you, on the other hand, are going with a S/C installation!
Good luck man!!!!!
Old Nov 29, 2006 | 11:50 AM
fijbert's Avatar
my friends all S/Ced their G/Z and the dealership warrantied it (they did it)
Old Nov 29, 2006 | 03:04 PM
Q45tech's Avatar
Members seem confused.
The Nissan warranty is between you and Nissan the dealer is just a repair facility that Nissan has a agreement with to do the repair work.
If they find something they can get reimbursement from Nissan to do, they do it, otherwise you pay............Nissans greatest problem is dealers doing things - doing too much and trying to fool Nissan into paying for under warranty.
Think of the service department as an independent business from new or used car lot [sales] same with the parts department [inventory] separate ops under a common roof.
"MAINTENANCE AND RECORDS
As a condition of this warranty, you are responsible for properly using, maintaining and caring for your vehicle as outlined in the owner’s manual, and maintaining copies of all maintenance records and receipts for review by Nissan. Failure to do so is likely to result in the denial of warranty coverage. Evidence of the performance of the required maintenance should be kept and presented as proof of such maintenance in connection with related warranty repairs. To assist you in maintaining appropriate record, the Maintenance Log Booklet, located in the information folder, can be used along with supporting repair invoices, receipts and other such records. Your Nissan dealer’s records are adequate proof of maintenance, but copies should always be retained."..........................
"This warranty does not cover damage, failures or corrosion resulting from:
misuse (proper use I outlined in the owner’s manual).
Alteration, tampering or improper repair.
Installation of non-Nissan approved accessories or components.
Improper installation of any Nissan-approved or aftermarket accessory or component
Old Nov 30, 2006 | 09:57 AM
da mayor's Avatar
i work at a dealership. you can mod the car but if the mod caused the problem to be not warrantied then you're in trouble. for example, if the s/c caused the engine to blow then it's not covered or if you overrev the engine and it blows you're not covered.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
slider_ua
Jul 29, 2015 04:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
