Vortech Supercharger
Old Nov 5, 2003 | 04:32 AM
humanRESEARCH's Avatar
Of course, this is for the Z too, but know-how/money can get this under our hoods too...
412HP and 355 Lb-Ft of torque...Fuel system upgraded with high-flow fuel pump and management...Stand-alone ignition timing computer...Oil feed and drain assemblies for cooling and lubricating...High-flow air filter (reusable)...Compatible with OBD-II, and has a 3-year warranty (possible the most attractive feature after the HP and torque gains...
No one posted this, so I figured I'd help with the heads-up...
"All the Power in the World resides in the Eyes..."
Old Nov 5, 2003 | 05:11 AM
kwakman's Avatar
Re: Vortech Supercharger
is that 412 hp and 355 lb/ft of torque to the wheels or at the crank? if that's to the wheels...WOW, put me on the waiting list. hehe
'03 G35c DG/G 6mt, full options
Old Nov 5, 2003 | 05:26 AM
gdupg35's Avatar
Is it intercooled?
Old Nov 5, 2003 | 10:39 AM
bought's Avatar
I believe what the news is about the intercooler is this. Vortech, who usually uses air-to-water intercoolers, has used the same intercooler as ATI (air-to-air). They say they did this to cut costs as the engine bay in the Z/G is quite small and would require alot of modifications. Again this is straight from one of the guys at ATI...from what I remember. Hope this helps....
Old Nov 5, 2003 | 04:12 PM
Bought is correct...I like the warranty too...Thinking this might be more attractive than the ATI, but I like their equipment as well...
Old Nov 6, 2003 | 04:12 PM
KjbAlto's Avatar
That's 412 to the crank.
Old Nov 7, 2003 | 02:48 PM
jdove's Avatar
Some other potentially attractive feature of the Vortech vs. ATI.
a) the Vortech SQ unit is probalby quieter , especially at idle and low RPM
b) the ATI head unit sits very far forward which forced ATI to ditch any pre-SC Air filter. Instead they put it after the IC and this is proven to rob psi and hence power. The vortech unit , sits further back , so it will most likely be easier to retro-fit a pre-SC Air filter with some simple plumbing onn the G35.
c) the kit uncludes a timing controller which makes protection against detonation and damage eaiser to control. A "great" safety measure for out of the box operation.
d) Current prices $4,749.00 for Vortech, $5,449.00 for ATI.
Use thes aved $700 towards the injector and ECU upgrades.
e) Vortech is aggressivley seeking CARB exemption.
I can't wait til someone adds bigger injector and get TS etc to re-tune the ECU for this setup. Then you can ditch the FMU and the external timing controller.
IMHO
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
9tray turbo
Sep 29, 2015 10:22 PM
n2fooz
Sep 4, 2015 07:46 PM
